just use Olarila folder with my dsdt and enable ec0 to ec patch
1 hour ago, kaitouhayashi said:
I did it but nothing change :(
the patches is done, check ur procedure
  • Thanks 1
2 hours ago, kaitouhayashi said:
You mean I only need copy & paste your dsdt into efi/clover/acpi/patched and do it (image)?
yes and video patch if need
28 minutes ago, kaitouhayashi said:
but do u know my brightness slider isn't useable? It's only displayed but isn't useable :(
check PNLF from whatevergreen kext and change Name (_UID
@onemanosx,
i have dell xps 9350, now i want to patch brightness key to f11 and f12. but i can't apply the EC query patch, no change is made when i want to apply the patch
is there any other way to identify the EC query for F11 and F12 on my xps 9350?
26 minutes ago, aryaone said:
dell xps 9350
dell is via BRT6
35 minutes ago, aryaone said:
can you give me the patch for DSDT?
into method label BRT6 replace_content
begin
    If (LEqual (Arg0, One))\n
    {\n
// Brightness Up\n
        Notify (^^LPCB.PS2K, 0x0406)\n
    }\n
    If (And (Arg0, 0x02))\n
    {\n
// Brightness Down\n
        Notify (^^LPCB.PS2K, 0x0405)\n
    }\n
end;
into device label PS2K insert
begin
Method (_DSM, 4, NotSerialized)  // _DSM: Device-Specific Method\n
    {\n
        If (!Arg2)\n
        {\n
            Return (Buffer ()\n
            {\n
                 0x03\n
            })\n
        }\n
        Return (Package ()\n
        {\n
            "RM,oem-id", \n
            "DELL", \n
            "RM,oem-table-id", \n
            "WN09"\n
        })\n
    }\n
end
5 minutes ago, BloodRace said:
How do I know my Brightness hotkeys if F2 and F3 has the same ACPIDebug result : EC_ Q13 both.
into method label _Q13 replace_content
begin
Store(HKNO, Local0)\n
If (LEqual(Local0,7))\n
{\n
    Notify(\_SB.PCI0.LPCB.PS2K, 0x0405)\n
}\n
If (LEqual(Local0,8))\n
{\n
// Brightness Up\n
    Notify(\_SB.PCI0.LPCB.PS2K, 0x0406)\n
}\n
If (LEqual(Local0,4))\n
{\n
// Mirror toggle\n
    Notify(\_SB.PCI0.LPCB.PS2K, 0x046e)\n
}\n
end
Hey, how do you set the keys to adjust the screen brightness on a laptop keyboard ??  Right now it's fn + f12 and fn + prtsc.  My bootloader is opencore. In my laptop, the shortcut from adjusting the screen brightness on the keyboard is the shortcut fn + left key and fn + right key.
check 0x86 inside q_xx into ur dsdt
This worked, but when I try to increase the brightness by one tap, it increases continuously until 3 bars. Decreasing brightness is the same case. How do I fix this?
use ssdt pnlf provide by whatevergreen
Thanks for your reply!
Unfortunately after using WEG's SSDT PNLF, it' still the same :( And I have to change all 'GFX0' to 'IGPU' in the WEG's SSDT PNLF to make the brightness slider works again.
Here's my DSDT.aml, SSDT.aml, and SSDT PNLF.aml if you're curious. Oh and my laptop is MSi GP62MVR 7RFX
DSDT.aml SSDT-PNLF.aml ssdt.aml
what ur hardware? processor?
