[Guide] - SSDT with Pike's PM Script and use with CPUFriend
Thanks MSI, great guide, really well described.
My question is:
I have XCPM active, if using the frequency injector via SSDT or kext, there is a further increase in performance?
Asus M12F - i9 10900k - RAM 32GB - RX5700XT SE Nitro+ 8GB - BS 11.1
My question is:
u don't need
18 minutes ago, Alexander Wang said:
SO I can generate with ssdtGen.sh just fine but when I go to cpu friend to get the C-frequency or make a kext file I keep getting file does not exist.
u just need a SSDT.aml, don't need a extra procedure ;)
1 minute ago, Alexander Wang said:
I understand Daniel you say I don't need the extra step but. CPU management is not working with droped SSDTs. It will not boot with type-in etc. Here is my SSDT that I generated.
ye, but extra procedure is just for skylake+ processors for fix bug HWP, u don't need it
what smbios u use now?
So if i boot using the Olarila usb image which use an macbook air 2012 smbios. Pc gadgets works and shows 3.4Ghz however wifi usb breaks and i guess handoff does to. When i use Imac or mac mini its in reverse. Any ideas?
run command inside this folder in ur desktop and check what native PM tables
Patchmatic.zip
On 1/5/2019 at 7:17 AM, onemanosx said:
Some of us might prefer to use injector kext instead of SSDT. This is how its done.
Creating injector kext with CPUFriend script
1. Type
./ResourceConverter.sh --kext
On 1/5/2019 at 3:50 AM, onemanosx said:
Step B: Generating SSDT data using CPUFriend script
1. Download CPUFriend master zip https://github.com/acidanthera/CPUFriend
While you’re there, download CPUFriend kext from the release tab and place the kext in Clover/Kext/Other
2. Extract CPUFriend-master folder to desktop
3. Open terminal
4. Type
cd ~/Desktop/CPUFriend-master/Tools
Hit Enter
5. Type
./ResourceConverter.sh --acpi
When i type one of these commands "./ResourceConverter.sh --kext" or "./ResourceConverter.sh --acpi", none of them works. I get an error message in Terminal, "Does not exist!". I downloaded CPUFriend-master.zip, extracted to desktop and ran the commands (cd ~/Desktop/CPUFriend-master/Tools & ./ResourceConverter.sh --kext/--acpi) , and didn't work... Is this because of the version of my donwload? Do you have a older version of CPUFriend-master? Have you ever seen any case like this?
Will this work on lates i7 9750h?
if the ssdt is injected correct do i need to put cpufriend on ACPI? I’m using opencore btw.
Edited by Kyaalod
Edit words
work for all
ssdtgen said my CPU is not supported. I have i7-10700 comet lake processor and I've put data into the User Defined.cfg file, but it still doesn't recognized.
How can I add it?
19 minutes ago, thief_fighter said:
I have i7-10700
u don't need it
  • Thanks 1
16 minutes ago, thief_fighter said:
Do you know why my Geekbench and Cinebench result is 10% lower in Mac compare with Windows?
no idea
I can't generate, where I'm wrong I use Big sur
advice
Edited by iFabio
