[Guide] - SSDT with Pike's PM Script and use with CPUFriend
No support for mobile processors? :(
Laptops and Desktops with Intel processors are supported
Donate
Gitter Chat
MSI B360 Gaming Arctic
I was found out that the Coffe Lake data file does not have the i7 8750h, what should I do then?
read second post
Donate
Gitter Chat
[ref]janjao[/ref], for mobiles ye, desktop don't need it, but u can use too
[ref]onemanosx[/ref], my battery still drains very fast. SSDT copied on clover/acpi/patch. CPUFriend.kext and CPUFriendDataProvider.kext on kext/other folder. But upon checking on IOREG I cannot see cf frequency, can you tell me how to fix that, thank you.
Edit; I think I finally I got it sorted :crazy: , thank you for detailed guide :cap:guitar
<IMGUR id="tHI2WQi"><a href=https://i.imgur.com/tHI2WQi.png' alt='IMGUR>'>
ssdt.aml.zip
Great! On other note, you might want to have EC0 to EC rename to load "AppleBusPowerController" i.e Apple's USB power properties
Donate
Gitter Chat
do you mean from my config.plist?
Yes.
Rename EC0 to EC
Find: 45 43 30 5F
Replace: 45 43 5F 5F
Donate
Gitter Chat
Is this method for CPU after first generation i7? I have a i7-920m CPU can I use this method for that CPU?
OP-LP3 OverPowered Laptop 17 inch, i7-8750H, 32GB memory, 256GB NvMe stock with windows 10 and added 512GB NvMe Samsung 970 Pro with MacOS 11.2.1, OpenCore 0.6.7.   New Asus Pro WS X299 Sage II intel i9-10980XE 18 core beast Big Sur 11.2.1. OpenCore 0.6.7,  Asus Z390-E i9-9900K 64GB G.Skill Ripjaws Sapphire Pulse RX580, Asus Sabertooth X79 (4) E5-2697 v2 (12 Core), Asus Maximus VIII Hero Alpha i7-7700K 64GB Corsair 2400, Asus Z97-Deluxe i7-4790K, Gigabyte Z77X-UP5-TH i7-3770k, Asus Maximux Formula Special Editions with Rampage Formula Bios conversion, Gigabyte GA-EP35-DS4, GA-EP45-UD3P, GA-G41M-ES2L, GA-Z68X-UD4-B3 and Quo MB.  MAC PRO EARLY 2008, MacPro Late 2012. Asus Notebooks: G51JX i7-720QM, G74SX-XT1 i7-2630QM, Asus G750JX-DB71 Haswell Processor i7-4700HQ GTX 770M 3GB (4).  Dell Laptops D820, D830, XPS M1530 (6), Dell 13-1567 (4), Older processors  i7 (3770K/4770k/6700k/7700K).  Older GFX Cards:  EVGA GT-640, EVGA GTX 760, EVGA GTX 770 (six),
for first gen cpu just use SSDT only. CPUfriend is not required.
Other easier link to achieve the ssdt by using automated script https://Olarila.com/forum/viewtopic.php?f=28&t=10897
Donate
Gitter Chat
Maybe this processor is not supported in PRgen? Tried it and get an error unsupported. Looked over a bunch of CFG files and I don't see anything less than 2nd generation intel i7/i5/i3. I will see if adding this CPU to the CFG will help any but is that the only reason why for the error or os it possible PRgen was not coded to work with 1st generation CPU?
Hi,
I get an error...
p.jpeg?fv_content=true&size_mode=5
Could this be that my DSDT is wrong?
Also, when I go to paste the frequency info, I have no _DSM:
ASUS P9X79 Pro - i7 3930K
in the data folder that is in your ⁨Users⁩ ▸ yourname ▸ ⁨LibraryssdtPRGen⁩ data folder in the user defined doc did you add as so
i7-8750H,35,600,2200,4100,6,12
as i added an give it a try
User Defined.cfg.zip
Hey I got also the i7-8750H, I wonder if lowering the tdp data does help saving energy? Also what is that 600 value which I cannot seem to find at intel’s website and current post Data folder contains the cpu but instead of 600 it has there a 500 value. How do you get default value for a cpu and how do you define which value is better?
Thanks.
i tried this with a macpro 6,1 smbios and ssdtPRGen seemed to run fine. i then added the cf-frequency-data, ran it through iasl and put the result in clover's patched folder. during verbose boot i could see the success message from X86PlatformPlugin. i have also set clover's plugin type to 1 and used the haswell-e fakecpuid because 10.12 wouldn't boot with the original broadwell id.
however, it had no effect. the frequency graph of Intel's Power Gadget was still straight. no vertical movement at all.
i did this with 10.12.6 and with windows the power management works fine. so i guess my bios settings are okay. so what did i miss?
I can't generate CPUFriendDataProvider.kext where I'm wrong
fabio@Fabios-iMac ~ % cd ~/Desktop/CPUFriend-master/Tools
fabio@Fabios-iMac Tools % ./ResourceConverter.sh --kext/Users/fabio/Library/ssdtPRGen/ssdt.aml
Invaild option: --kext/Users/fabio/Library/ssdtPRGen/ssdt.aml
Usage:
-a, --acpi file Create CPUFriendDataProvider.kext with information provided by file.
-k, --kext file Create ssdt_data.dsl with information provided by file.
Added in 4 minutes 10 seconds:
Looks like spacing
./ResourceConverter.sh --kext /Users/fabio/Library/ssdtPRGen/ssdt.aml
Donate
Gitter Chat
