[Guide] - SSDT with Pike's PM Script and use with CPUFriend
cf-frequency-data should show in ioreg
https://imgur.com/y0bJFEL
When I compiled the file, I said 0 corrections, this is so?
or should I put 1 correction
*HP Notebook 15 bs527ns*
Intel i5-7200U , 8 GB 2133 MHz DDR4, Intel HD Graphics 620 - 2048 MB
*Asus F55VD*
Intel i3-3110M , 8GB 1333MHz DDR3, Intel HD 4000 - 1536 MB
[ref]iSn0wCrypt0[/ref], try kext method instead of ssdt
Donate
Gitter Chat
MSI B360 Gaming Arctic
doesnt works
*Asus F55VD*
[ref]iSn0wCrypt0[/ref], this is something you have to do it on your own
Donate
Gitter Chat
If I can explain myself well, I speak English very badly!
perform all the steps of the post ... but it does not work for me, as you already know
you told me to perform the steps with the option of kext ..
Now I can not move from here: ./ssdtPRGen.sh -p 'i5-7200' -f 2500 -turbo 3100
send me an announcement: not such directory
Paste my .cfg, but I still throwing the same error
https://imgur.com/Oqi5YgW
*Asus F55VD*
Did you place pike's folder in the directory as instructed? Did you replace the Data folder? Did you key in your CPU type in the .cfg file as instructed? You will need to go through it slowly. Good luck.
Donate
Gitter Chat
I repeat, I followed all the steps to the letter
I have repeated it 20 times .. always the same CPU error
Everything is copied / pasted / and chewed thousands of times
Could you check if my ssdt.aml is correct?
2 weeks ago everything went well and compile the file without problems ..
But I had to restore from scratch and now I have this problem (because you said you would have to appear in IOreg) but it does not appear to me like you ..
Then can you look at my ssdt?
https://drive.google.com/file/d/1maE1v0BS4CYNZS2EQoEmtM-k6o01vb1k/view?usp=drivesdk
*Asus F55VD*
I cant check if I don't know exactly what you did. Anyone can claim they followed instructions to the letter but without proof, you see.
Anyway, ssdt looks good. So, as per my suggestion, using the existing files you had, you an easily create kext. Read post 2 of the guide.
Donate
Gitter Chat
First, thank you for answering ..
hello I decided to start again (post1) everything went perfect ..
but when restarting it stays stuck here ..
http://imgur.com/3E8VmxV
*Asus F55VD*
Hey guys. I got a 9700k. Do I need to do this procedure? (I already did, just want to know if its pointless). I read that 9900 was not necessary. Which models does not need this?
Moreover, after all this, do I need to uncheck PluginType in clover?
Thanks.
[ref]anibalin[/ref], desktops just use PlugIn type in config.plist, ssdt or dsdt
this way is for solve HWP bug in notebooks
https://www.insanelymac.com/forum/topic/321021-guide-hwpintel-speed-shift-enable-with-full-power-management/
Hi, everyone...
After the procedure to resolve Unknown CPU I have in finder same result even if in other applications the CPU is shown...
I have proceeded in this mode:
Downloaded:
curl -o ~/ssdtPRGen.sh https://raw.githubusercontent.com/Piker-Alpha/ssdtPRGen.sh/master/ssdtPRGen.sh
Copy our modded downloaded DATA folder https://Olarila.com/forum/download/file.php?id=16110
and edit "User Defined.cfg" with:
'E5-2695 v3',120,1200,2300,3300,14,28
after in the terminal
chmod +x ~/ssdtPRGen.sh
again...
sudo ~/ssdtPRGen.sh -p 'E5-2695 v3' -f 2300 -turbo 3300
cd ~/Desktop/CPUFriend-master/ResourceConverter
Download CPUFriend master zip https://github.com/acidanthera/CPUFriend
terminal:
./ResourceConverter.sh --acpi /Users/apple/Library/ssdtPRGen/SSDT.aml
Combining CPUFriend data into Pike's SSDT and save the ssdt.aml and copy to Clover/acpi/patched
Or NOT and...
2. Drag ssdt.aml from ~/Library/ssdtPRgen folder to terminal and Press Enter
3. Your CPUFriendDataProvider.kext will be generated and can be found at ~/Desktop/CPUFriend-master/ResourceConverter folder
4. Place both CPUFriendDataProvider.kext and CPUFriend.kext in clover/kext/others
./ResourceConverter.sh --kext /Users/apple/Library/ssdtPRGen/SSDT.aml
and also
sudo chmod -R 755 kextfile.kext
sudo chown -R root:wheel kextfile.kext
But the CPU in Finder (about this MAC) result unknown (sconosciuta in italian)
Many thanks
Nasca.
