[Guide] - SSDT with Pike's PM Script and use with CPUFriend
Update: Creating injector kext with CPUFriend script
What is CPUFriend?
https://github.com/acidanthera/CPUFriend
https://www.insanelymac.com/forum/topic/335162-cpufriend/
Step A. Creating SSDT Using Pike's Script
1. Go to Pike’s Github and download ZIP master https://github.com/Piker-Alpha/ssdtPRGen.sh
2. Extract “ssdtPRGen.” folder and copy and paste to /Users/YourUsername/Library
4. Download attached “Data” folder and replace existing Data folder in “/ssdtPRGen”
Data.zip
5. Open “User Defined.cfg” file in “ssdtPRGen/Data” folder
6. Open Coffee Lake.cfg file and look for your processor type ( in this example, I will be using “i5-8600”)
7. Paste your CPU details in User Defined.cfg and save file
Note: If you plan to use a different clock speed frequency (mostly for energy saving) or base/turbo frequency, here is where you make the desired frequency changes. The example in the screenshot above is setting using clock speed of 500 instead of OEM 800.
8. Open Terminal
9. Type
cd ~/Library/ssdtPRGen/
Hit Enter
10. Type CPU format as such (for i5-8600) :
./ssdtPRGen.sh -p 'i5-8600' -f 3100 -turbo 4300
11. Press Enter
12. Let the script run and when script asks Do you want to open ssdt.dsl (y/n)? Just return N.
13. Your ssdt.aml and ssdt.dsl can be found in ~/Library/ssdtPRgen folder
Step B: Generating SSDT data using CPUFriend script
1. Download CPUFriend master zip https://github.com/acidanthera/CPUFriend
While you’re there, download CPUFriend kext from the release tab and place the kext in Clover/Kext/Other
2. Extract CPUFriend-master folder to desktop
3. Open terminal
4. Type
cd ~/Desktop/CPUFriend-master/Tools
Hit Enter
5. Type
./ResourceConverter.sh --acpi
Then drag ssdt.aml from ~/Library/ssdtPRgen folder into terminal window and press ENTER
6. Your ssdt-data.dsl result can be found at ~/Desktop/CPUFriend-master/Tools folder
Step ? Combining CPUFriend data into Pike's SSDT
1. Open the ssdt-data.dsl and copy the whole scope of “cf-frequency-data”
2. Go to ~/Library/ssdtPRgen folder and open the file ssdt.aml
3. Find the _DSM section
4. Paste “cf-frequency-data’ like shown in the screenshot. Also, delete 0x02 in the Return line leaving just the brackets or else your will not be able to compile.
5. You can save the ssdt.aml and copy to Clover/acpi/patched.
Reboot and enjoy!
Note: If you do not find the cf-frequency-data as shown like in the IOReg screenshot below, it means the SSDT is not injecting properly. You might want to consider creating CPUFriendDataProvider kext instead.
Data.zip
Credits:
https://www.elitemacx86.com/threads/guide-how-to-generate-ssdt-for-coffee-lake-cpu.98/
Pike
Donate
Gitter Chat
MSI B360 Gaming Arctic
Some of us might prefer to use injector kext instead of SSDT. This is how its done.
1. Type
./ResourceConverter.sh --kext
2. Drag ssdt.aml from ~/Library/ssdtPRgen folder to terminal and Press Enter
3. Your CPUFriendDataProvider.kext will be generated and can be found at ~/Desktop/CPUFriend-master/Tools folder
4. Place both CPUFriendDataProvider.kext and CPUFriend.kext in clover/kext/others
Unknown CPU
What if I have a CPU that is unknown and not in the .cfg list? Can I still generate ssdt using Pike's script?
Yes. And this is what we have to do.
1. Determine CPU details by going through https://ark.intel.com and fill in the details for an i5-8600 as an example.
Code Name: Coffee Lake
Processor Number: i5-8600
Max TDP: 65
Low Frequency Mode: 3100
Clock Speed: 800
Max Turbo Frequency: 4300
No. of Cores: 6
No. of Threads: 6
The format to be input in Coffee Lake. cfg and User Defined.cfg will look like this
i5-8600,65,800,3100,4300,6,6
Donate
Gitter Chat
:guitar:cap
:guitar:cap
A good sleep is all I need :lol::lol:
Donate
Gitter Chat
:superman:superman:superman:superman
:superman:superman
[ref]vinvilli[/ref], :guitar:cap You're welcome!
Donate
Gitter Chat
[ref]agussuratno[/ref], :guitar:guitar You're welcome!
Donate
Gitter Chat
[ref]FedeBad95[/ref], u don't need it
[ref]brynts[/ref], never experienced that in all of my 4 hack machines.
Donate
Gitter Chat
[ref]brynts[/ref], if u don't like .aml/.dsl, generate a kext injector instead
Completed with cpufriend
with out cpufriend
:cap
51816618_227026154913049_5118793812088455168_n.png.34dd668522af92d7ceef62f9d7947fcb.png
:superman:superman
with out cpufriend
:cap
:mrgreen:
[ref]MaLd0n[/ref], [ref]erroruser[/ref], please do one with overclocked settings :whistle:geek::mrgreen:
Donate
Gitter Chat
[ref]onemanosx[/ref],
with i9 i forgot the overclock :mrgreen:
