I have two SSDT one renames PCI0.NPE7.display@0 to PCI0.NPE7.GFX2. The other injects some properties and functions for the same device using its scope. How can I add the device rename to the dsl-file in the attached zip?
I want to add the rename of display@0 to GFX2 from SSDt-renameGFX.aml to the SSDT-RX580.dsl so I have it in one working file.
SSDT-combine.zip
[ref]xayide[/ref], why need rename it? whatevergreen kext solve all, use last version
[ref]xayide[/ref], weg kext is best solution, fix all we need
