Voodooi2celan is not compatible with your trackpad. Did you uncheck the setting in accessibility preferences?
yes i did. btw with voodooi2chid trackpad preference not appear in system pref.
[ref]dinimuhtar[/ref], In that case, I have no idea whats the problem. By default, your trackpad should work in polling mode. Try upgrading bios if its available. Because, I recall a bios update solved another user with his Asus laptop trackpad Elan1200 issues.
Also, enable advanced option for trackpad in bios if option is available.
Donate
Gitter Chat
MSI B360 Gaming Arctic
[ref]comcomson[/ref], Lets try this. Boot and upload new sendme.
DSDT-01.aml.zip
Also, check in bios if there is an option to set track pad as advanced.
Donate
Gitter Chat
DSDT-01.aml.zip
For bios, there's no option about trackpad
Replaced with your dsdt and trackpad still not working
Here's the latest send me file
Added in 1 minute 6 seconds:
send me file with your dsdt:
Send me Comsons-MacBook-Pro.zip
[ref]comcomson[/ref], While I find no irregularities in voodooi2c logs, there are however logs for TPD0.INI. This, I think is the key and no where in dev documentation. Try to load the attached DSDT and upload yet another sendme.
DSDT-02.aml.zip
Also, upload unpatched DSDT for native code comparison.
kernel: (AppleACPIPlatform) [\_SB.PCI0.I2C0.TPD0._INI] (Node ffffff803583a000)
kernel: (AppleACPIPlatform) , AE_NOT_EXIST
kernel: (AppleACPIPlatform)  (20160930/psparse-632)
kernel: (AppleACPIPlatform) ACPI Exception: AE_NOT_EXIST,
kernel: (AppleACPIPlatform) during \_SB.PCI0.I2C0.TPD0._INI execution
kernel: (AppleACPIPlatform)  (20160930/nsinit-770)
[ref]MaLd0n[/ref], Any idea on ACPI table TPD0._INI? Maybe Return (0x0F) instead will activate?
Donate
Gitter Chat
DSDT-02.aml.zip
Will upload original DSDT folder later. Here's the send me file after apply your latest DDST
:D:D before you can fix my problem, I really need to say big thanks to you :superman:superman
Added in 2 minutes 42 seconds:
EXtracted from clover F4 original DSDT folder
DSDT.zip
[ref]comcomson[/ref], My suspicion was correct for the ACPI table error in the log. Please try these DSDTs and lets see the logs.
DSDT-03.aml.zip <-- Native code
DSDT-03-1.aml.zip <-- modded for acpi error
New sendme files are appreciated for both instances.
Kernel log for TPD0 has changed using the previous DSDT. This confirms my suspicion.
kernel: (AppleACPIPlatform) ACPI Warning: \_SB.PCI0.I2C0.TPD0._DSM:
VoodooI2C log now looks promising
kernel: (kernel) VoodooI2CPCIController::pci8086,9de8 Starting I2C controller
kernel: (kernel) VoodooI2CPCIController::pci8086,9de8 Set PCI power state D0
kernel: (kernel) VoodooI2CPCIController::pci8086,9de8 Publishing nub
kernel: (kernel) VoodooI2CControllerDriver::pci8086,9de8 Found valid Synopsys component, continuing with initialisation
kernel: (kernel) VoodooI2CControllerNub::pci8086,9de8 SSCN not implemented in ACPI tables
kernel: (kernel) VoodooI2CControllerNub::pci8086,9de8 FMCN not implemented in ACPI tables
kernel: (kernel) VoodooI2CControllerDriver::pci8086,9de8 Warning: Error getting bus config, using defaults where necessary
kernel: (kernel) VoodooI2CControllerDriver::pci8086,9de8 Publishing device nubs
kernel: (kernel) VoodooI2CControllerDriver::pci8086,9de8 Found I2C device: XXXX0000
kernel: (kernel) VoodooI2CControllerDriver::VoodooI2CDeviceNub Warning: Incompatible APIC interrupt pin (0x33 > 0x2f) and no GPIO interrupts found; if your chosen satellite implements polling then VoodooI2CDeviceNub will run in polling mode.
:D :D before you can fix my problem, I really need to say big thanks to you :superman :superman
As long as you are patient and willing to test. I am more than willing to try :)
Donate
Gitter Chat
I'm unable to boot up using first dsdt file. It enters black screen after clover -v booting.
for the modded for acpi error one, the touchpad still not working. Here's the send me file
Send me Comsons-MacBook-Pro_acpi_fix.zip
[ref]comcomson[/ref], try it instead VoodooI2CHID.kext
VoodooI2CSynaptics.kext.zip
rebuild cache
[ref]MaLd0n[/ref], Thanks Maldon!
In any case, I created two more DSDTs
1. activating GPI0 in Polling mode - DSDT-GPI0.aml.zip
2. Interrupt mode - DSDT-Interupt.aml.zip
Current, log has shown correct HID Device now. Either one of the DSDT should work, theoretically. :mrgreen:
[ref]comcomson[/ref], Try both of these DSDT with VoodooI2cHID. Then try with synaptics if dont work.
Donate
Gitter Chat
rebuild cache
I tried both removing HID kext or while adding syntactic kext. Still no luck. :(
If I simply add in without removing HID KEXT, it still doesn't work.
Here's the latest send me file without HID but with new driver Please take a look :D
Gonna try onemanosx's 2 dsdt edits now :)
Both dsdt not working. IOname shown but I wonder if the a IOName is correct shown in IOREG. Shouldn't it be MSFT0001? It shows as MSFT0001 on windows.
Will upload send me file in minutes
Now trying with synaptioc drivers again.
Added in 19 minutes 36 seconds:
Okay I tried all scenarios. None of them are working. I am uploading 4 send me file, 2 are HID kexts, others are synaptics
Let's check what problems inside. Million thanks for efforts.
Added in 2 minutes 8 seconds:
attached. thanks for investigation. :cap:cap
interrupt_mode.zip
interrupt_with_synaptics.zip
polling_mode.zip
polling_with_synaptics.zip
If this is the case, you can simply make the change manually at scope I2C0.TPDO like so. See if this will work with the last 2 DSDT
https://imgur.com/fpACPcx
Donate
Gitter Chat
[ref]comcomson[/ref], I have a couple more ideas.
Lets try this, I will still be online for the next 1/2 hr ;)
We should be trying with polling mode first. But, what the heck! LOL!
Donate
Gitter Chat
[ref]comcomson[/ref], On a side note, you are using AcpiBatteryManager with VirtualSMC where its supposed to be SMCBatteryManager+VirtualSMC kexts. I have read, SMCBatteryManager kext works better for newer I2C devices.
Also, you may remove these two plugins from voodoops2controller to avoid conflict
https://imgur.com/vpIQVlZ
Can you replace the HID to MSFT0001 and try again?
Donate
Gitter Chat
-replaced XXXX0000 with MSFT0001
-replaced with SMCBatteryManager
not working. send me file below
send me file
[ref]comcomson[/ref], The HID was not changed yet, I think you made a mistake.
https://imgur.com/wOQqTG0
PS: Check my reply earlier regarding voodoops2controller plugin.
Donate
Gitter Chat
[ref]iki[/ref], DSDT.aml.zip
check if work, replace dsdt, rebuild, reboot
sudo kextcache -i /
