[ref]juanvascas[/ref], reboot?
Hackintosh combojack support for alc256/alc255.
Confirmed to work on dell xps 13 9350/9360(alc256) and Xiaomi Air(i5-7200U, alc255)
1. Delete CodecCommander.kext,put ComboJack_Installer/VerbStub.kext in Clover/kexts/Other
2. Run ComboJack_Installer/install.sh in terminal and reboot
3. Done. When you attach a headphone there will be a popup asking about headphone type.
Donate
Gitter Chat
MSI B360 Gaming Arctic
[ref]juanvascas[/ref], All you need is Lilu+ AppleALC kext. It is worth to test every layout id and find which works best.
Donate
Gitter Chat
I am actually not using AppleALC, I once saw it in a post but it said ALC256 has to use clover boot flag of applealcbeta, should I? Also was the solution you told me a couple days before planned with AppleALC?
the bootflag ia not required. And yes, the solution ia for applealc only.
Donate
Gitter Chat
Hey you audio solution worked! I am not sure why on like the third try it worked. I am now seeking to have a patched DSDT, however I once used a DSDT which is the one from this post:
I think I have finally got it working patching the DSDT. It may be a lot of work to get all SSDT patches to the DSDT so I may rely on hotpatches. I am unsure how to create a proper SSDT out of the DSDT to enable the I2C. Can you help me get it?
Oh I also applied the Windows 10 patch from the VoodooI2C repo in case it has to be added to the SSDT as well.
However I was trying to make a new one with different patches and my PC reboots, tried with the one that I first had VoodooI2C on interrupt mode which is the one from the post above and same. Even with the intact one you once fixed for me reboots at the middle of macOS loading, which is weird because I once was able to boot and I am tried with the config.plist I was using at the time you started helping me.
I wonder if the system DSDT changed somehow so I want to get a new clean DSDT.dsl for patching and I would like to ask if you can decompile it and fix errors if possible so I can try again.
I do not want to decompile it with RehabMan iASL as it may be too old but I am not sure how to compile the latest one. Did to understand from the repo that has latest MaciASL
Also I get a somehow slow boot, it seems like Clover applies the DSDT hot patches from the config.plist multiple times according to the bootlog right?
Thanks!
origin.zip
bootlog.txt
[ref]juanvascas[/ref], When you apply a patch directly to DSDT, you should also remove all related clover patches referenced to it.
Donate
Gitter Chat
I did however there is something with VoodooI2C that I better figure out at last when I get a DSDT with patches except for the trackpad.
I even tried applying just the BRT6 ssdt so I can use the brightness keys, disabled the clover patch and it didn't work which I though was an easy patch. :frantics
[ref]juanvascas[/ref], I suggest you disable any hot patches in clover and patch manually on DSDT (Since most of the patches are already directly implemented.
For brightness hot keys : https://Olarila.com/forum/viewtopic.php?f=28&t=8396
Donate
Gitter Chat
[ref]rals2007[/ref], DSDT.aml.zip
change GFX0 to IGPU
47465830
49475055
change HDAS to HDEF
48444153
48444546
change HECI to IMEI
48454349
494d4549
change SAT0 to SATA
53415430
53415441
[ref]rals2007[/ref], Use this DSDT, add renames, add voodooi2c kexts, reboot and extract ioreg
[ref]MaLd0n[/ref],
Here it is. booted as per instruction.
Which sets of voodooI2c kexts did you boot with?
Donate
Gitter Chat
[ref]rals2007[/ref], Looking at your ioreg, I think your voodooI2C kexts are not injected. Can you upload new sendme files?
Donate
Gitter Chat
