my touch screen worked ob through usb
Product ID:0xc04d Vendor ID: 0x0eef (D-WAV SCIENTIFIC CO., LTD.)
:superman:superman
My IOReg show the same I2C devices, do I dont know what to do next :)
Still have not learned how to attach the screenshot from gallery.
Maybe read post #1?
Donate
Gitter Chat
MSI B360 Gaming Arctic
It is nice to hear that it may work. What should I do to enable it when it does not work? I see there is no dedicated touchscreen thread on the forum.
some just work same as sd cards as some are an not supported as depending on the manufacture of the devices an not sure if a dsdt ssdt will fix it either
:superman:superman
@onemanosx
Any help for the I2C Trackpad on Coffee Lake?
AFAIK, there are no coffee lake support for now.
Donate
Gitter Chat
[ref]mathewgx[/ref], This is the code for my ssdt. I dont need xcrs or xsta in clover.
Let's see if you can recreate yours ;)
DefinitionBlock ("", "SSDT", 2, "ONEM", "i2cc", 0x00000000)
   External (_SB_.PCI0.I2C1, DeviceObj)    // (from opcode)
   Scope (\_SB.PCI0.I2C1)
       Name (_STA, Zero)  // _STA: Status
       Device (TPD1)
           Name (_HID, "SYN1B7F")  // _HID: Hardware ID
           Name (SBFG, ResourceTemplate ()
               GpioInt (Level, ActiveLow, ExclusiveAndWake, PullDefault, 0x0000,
                   "\\_SB.PCI0.GPI0", 0x00, ResourceConsumer, ,
                   {   // Pin list
                       0x1B00
           Method (_CRS, 0, Serialized)  // _CRS: Current Resource Settings
               Name (SBFB, ResourceTemplate ()
                   I2cSerialBusV2 (0x002C, ControllerInitiated, 0x00061A80,
                       AddressingMode7Bit, "\\_SB.PCI0.I2C1",
                       0x00, ResourceConsumer, , Exclusive,
               Return (ConcatenateResTemplate (SBFB, SBFG))
I have the same problem with fix SYN17BF...
I use this tool but my trackpad not works.. https://github.com/williambj1/GenI2C
I upload my debug! I don´t know because i have others laptops and works my patches
. The laptop is Xiaomi 13.3 i5 skylake
debug_23831.zip
[ref]hynrik[/ref], for some unknown reason I am no able to extract your debug files
Donate
Gitter Chat
[ref]hynrik[/ref], What is your device id? Use Windows to find out.
https://imgur.com/FIJPN8P
More info can be read at first post.
PS: I can see both of your i2c ssdt are not working. Should remove them and find out the device id, first.
Donate
Gitter Chat
[ref]hynrik[/ref],
1. Place DSDT.aml in clover/acpi/patched folder.
2. Remove ssdt-TPD1 and/or TPD0.
3. Remove ssdt-xosi.aml.
4. Reboot
5. upload runme folders RunMe
Donate
Gitter Chat
[ref]hynrik[/ref],
4. Reboot
runme.zip
[ref]hynrik[/ref], I am still not seeing your I2C device in ioreg. Are you sure its I2C? Can you reboot with previous settings plus disabled 'change GPI0._STA to XSTA" hot patch too? Then upload new ioreg file.
Donate
Gitter Chat
I'm not sure.
RunMe.zip
I'm not sure.
Neither do I.
Donate
Gitter Chat
