u need select rebase regions
Hello everyone.
I ask for help starting Trackpad.
I tried to do different SSDT-GPIOs, but nothing works.
My device is (I think so :-)
Device (TPD0)
Scope (_SB.PCI0.I2C0) ??? (But I'm not sure, because device TPD0 is in (_SB.PCI0.I2C1, _SB.PCI0.I2C2, _SB.PCI0.I2C3)
IOREG <28 00 00 00 03 00 00 00>
last try SSDT-GPIO-V5.aml. Does not work.
I just can't start. I ask for help.
DSDT_DSL.zip EFI 2.zip
Edited by member052018
2 hours ago, Christopher G said:
I have an Acer SF314-56G with SYN1B7F touchpad
if work nice in polling jus enjoy
many devices don't work in interrupt mode
Polling works, but then the cpu usage jumps and lags the touchpad.
This post has the same hardware as mine
Can you share the result with me?
Edited by Christopher G
u have many acpi renames. not a clean efi folder
opencore is not smart like clover. i need one full dump with runme.app with no renames and rebase regions select
On 10/14/2021 at 9:46 PM, member052018 said:
Hello everyone.
Device (TPD0)
From DSDT.dsl above, i didn't see any TP device attached to I2C Bus. Re-check what is your TP device via Win
I think the TDP0. I did it according to the instructions, but I can't see the device name in Win.
Report_new.htm.zip
I'm following this as I'm using open-core :
https://dortania.github.io/Getting-Started-With-ACPI/Laptops/trackpad-methods/manual.html#create-osys-variable-under-i2c-scope
The first part helped me to enable GPI0 and now I can see it in, "IORegistryExplorer" , Here's the file I used:
SSDT-GPI0.dsl
// Source: https://github.com/daliansky/OC-little
DefinitionBlock("", "SSDT", 2, "DRTNIA", "GPI0", 0)
    External(\GPEN, FieldUnitObj)
    If (_OSI("Darwin"))
        \GPEN = One
I understood that putting One would make it go well.
I then used SSDT-XOSI.aml from:
https://github.com/dortania/Getting-Started-With-ACPI/blob/master/extra-files/compiled/SSDT-XOSI.aml
also this
  • XOSI Rename (Add this under ACPI -> Patch in your config.plist):
Comment String Change _OSI to XOSI
Enabled Boolean YES
Count Number 0
Limit Number 0
Find Data 5f4f5349
Replace Data 584f5349
Then added voodooi2c and voodooi2celan kexts from :
https://github.com/VoodooI2C/VoodooI2C/releases/tag/2.6.5
and now I get these in the EFI/opencore-2021-12-07-065738.txt :
03:504 02:553 OC: Prelinked injection VoodooI2C.kext () - Invalid Parameter
03:532 00:028 OC: Prelinked injection VoodooI2CELAN.kext () - Invalid Parameter
Any idea what to do now?
I added these two from the same order, in the end, so no dependency problem should happen as far as I know.
Report file is 3mb can't upload as the limit is 2.93MB here, so put it on google drive:
https://drive.google.com/file/d/1R1G4zYBi263VrUFea518r2kdu4oEkqkb/view?usp=sharing
Also VoodooPS2Trackpad is disabled in the config.plist
Please also check the attachment, a bunch of useful pictures are there.
Archive.zip
SSDT-GPI0.dsl
    If (_OSI("Darwin"))
        \GPEN = One
also this
Enabled Boolean YES
Count Number 0
Limit Number 0
Find Data 5f4f5349
Fixed it by adding a few more things to my config.plist kexts :)
I had some dependencies inside The VoodooI2C Kext.
Now GENI2C shows polling mode instead of interrupt mode.
How? Can you give more detail please. I have Mojave running great but touchpad not.
after tried many times, still not working
I followed voodooi2c guide carefully:
  • correct my ACPI ID is TPD1, and know my CPU is Broadwell no need GPI0 controller patch, and I2C Controller Patches?
  • Windows Emulation patch will done with SSDT-XOSI.aml
  • Look at IOInterruptSpecifiers to know the hexadecimal APIC pin number is 0x1e mean 30 in decimal, less than 47, then can proceed to install kexts.
But at Step Ensure I2C Serial bus name is correctly labelled, I not sure about it. Here is original method from DSDT:
_SB.PCI0.I2C1.TPD1:
        Device (TPD1)
            Name (_ADR, One)  // _ADR: Address
            Method (_HID, 0, NotSerialized)  // _HID: Hardware ID
                If (LEqual (RDGI (0x35), One))
                    Return (0xB0068C11)
                Else
                    Return (0xAF068C11)
            Name (_CID, "PNP0C50")  // _CID: Compatible ID
            Name (_UID, One)  // _UID: Unique ID
            Name (_S0W, 0x04)  // _S0W: S0 Device Wake State
            Method (_DSM, 4, NotSerialized)  // _DSM: Device-Specific Method
                If (LEqual (Arg0, ToUUID ("3cdff6f7-4267-4555-ad05-b30a3d8938de") /* HID I2C Device */))
                    If (LEqual (Arg2, Zero))
                        If (LEqual (Arg1, One))
                            Return (Buffer (One)
                                 0x03
                        Else
                                 0x00
                    If (LEqual (Arg2, One))
                        Return (0x20)
                Else
                         0x00
                Return (Zero)
            Method (_STA, 0, NotSerialized)  // _STA: Status
                If (LEqual (And (SDS1, 0x08), 0x08))
                    Return (0x0F)
                Else
                    Return (Zero)
            Method (_CRS, 0, Serialized)  // _CRS: Current Resource Settings
                Name (SBFI, ResourceTemplate ()
                    I2cSerialBusV2 (0x002C, ControllerInitiated, 0x00061A80,
                        AddressingMode7Bit, "\\_SB.PCI0.I2C1",
                        0x00, ResourceConsumer, , Exclusive,
                    Interrupt (ResourceConsumer, Level, ActiveLow, Exclusive, ,, _Y2A)
                        0x0000001E,
                If (LEqual (GR13, One))
                    CreateDwordField (SBFI, \_SB.PCI0.I2C1.TPD1._CRS._Y2A._INT, VAL3)  // _INT: Interrupts
                    Store (0x1B, VAL3)
                If (LOr (LOr (LEqual (BID, 0x80), LEqual (BID, 0x82)), LEqual (BID, 0x83)))
                    CreateDwordField (SBFI, \_SB.PCI0.I2C1.TPD1._CRS._Y2A._INT, VAL4)  // _INT: Interrupts
                    Store (0x1A, VAL4)
                Return (SBFI)
I renamed SBFI to SBFB and remove:
                        0x0000001E,
But can't compile, so I removed these too:
                    Store (0x1B, VAL3)
                    Store (0x1A, VAL4)
Then compiled SSDT-TPD1.aml success (below attached files), put this SSDT-TPD1.aml in OC/ACPI and add to config.plist. Reboot and nothing change
Trackpad work like mouse, but Trackpad setting not show in system preferences, and nothing advance setting for trackpad in BIOS. Battery status + brighter slide working well
In IOReg, TPD1 show Interrupt mode is APIC, and can't see GPI0 - which I understand no need for Broadwell CPU right?1051016536_ScreenShot2022-09-08at19_52_19.png.085dbae0e5f1496e543d47c777005ad3.png
What were I missing? thank and regards!
With-SSDT-TPD1.ioreg
Without-SSDT-TPD1.ioreg
SSDT-TPD1.aml.zip
Edited by oldman20
use default olarila efi folder for ur hardware and post one sendme
thank @MaLd0n, just "use default olarila efi folder" without modify anything for my CPU?
Here it is:
https://drive.google.com/file/d/1jjaYiC5Bp40w_jLu58qkRz96s3diQVgr/view?usp=sharing
RunMe-Output.txt.zip
Edited by oldman20
