8 hours ago, Mike Wilson said:
Do I need to do name change for VoodooI2CHID.kext as well?
in VoodooI2CHID.kext no only if use VoodooI2CSynaptics.kext
Hello,
I am trying to install big sur or Catalina on my Lenovo Thinkbook 15 IML from last 15 days.
but every time i boot from USB i get into installer but the trackpad didn't work i have attached my DSDT to this post.
kindly tell what possible ways can to get trackpad fully working i am using OpenCore as bootloader here are some details of system
Processor
i5-10210u 10th gen
Trackpad
 I2C HID Device
Bios name
\_SB.PCI0.I2C0.TPD2
Hardware ID
ACPI\ELAN062F
Host Controller
PCI\VEN_8086&DEV_02E8&SUBSYS_383217AA&REV_00
Thanks,
Looking Forward for your quick response.
DSDT.aml
Hello! i am having trouble activating my i2c.
I have a DELL 7391 with CPU i7 10510U and if I try to activate I2C the mouse and keyboard no longer work .. also this pc is a 2in1 and also has a Touch Screen.
From ioreg everything is active in theory but in practice they do not work.
I am attaching my EFI, ACPI and ioreg hoped you can help me!
DELL 7391.zip
Hey @onemanosx and @MaLd0n looking for Help regarding my ELAN 1203 (INT3450) i have followed the installation guide but i got missing IOInterruptSpecifiers entries on ACPI ID TPD0 and but i am getting IOInterruptSpecifiers entries in GPI0 which is 0e.
My System Config
Asus Tuf Gaming F15
intel Core i7 10870H 8 core 16 Threats
16 GB DDR4 2933
ELAN 1203 (INT3450)
NVDIA 1660TI 6GB
Here are my files i am using lated VoodooI2C kext.
https://drive.google.com/drive/folders/1F1NfXpPB38vG34lWLcZjn0E3-eSkvyyM?usp=sharing
Edited by Dec_Bra1n
HackBook Pro :-HP DV6-6121 TX (Win 10 Pro + macOS 10.13.6 + OC )
Hac Pro:-GA-B365-D3H, Core i5 9440F AMD RX 580 8 GB (Win 10 Pro + macOS 10.15.7 + Big Sur Beta )
Hac Pro:-z97 sabertooth mark 2, Core i7- i7 4790k with GT 740 2GB and 32 GB Ram (OC+Catalina)
iHack:- Assus M2N68-AM-SE2,AMD Athlon+LE-1640,250 SSD ,4GB DD3 800MHZ Nvidia 9400GT (win 10 and 10.9.5+10.10.5)
iHack:-GA875M-D3H ,core-i5 3250,NVDIA 610-2GB 27"LED,8GB DDR3 1600mhz, (Only 10.10.5+10.11.6 with CLOVER)
iHack:-GA-78LMT-S2PT ,AMD Phenom II-X2 560,Radeon 6770 1 GB ,onboard Radeon HD 3000 not tested 4 GB DDR-3 1333 MHZ (10.11.6+Win 10 pro) Special thanks....  To Genius donovan6000 For Mode Bios (WiFi +BT Whitelist removed) & Amazing Hackintosh Guides and tutorial and much more visit this blog Hackintosh Mumbai
22 hours ago, Dec_Bra1n said:
Asus Tuf Gaming F15
check bios/uefi config if have things about trackpad
This is the only option i am having if i disable then touchpad got disable completly.
Edited by Dec_Bra1n
let me check ur efi folder
Here is my Current EFI
and my raw ssdt and dsdt are attached below. and i am having ELAN 1203 (INT3450)
18 hours ago, MaLd0n said:
why u add acpi renames? u kill devices
https://easyupload.io/m2nk9x
after reboot check ioreg
I am able to see Touchpad on System Preferences but my cursor not moving at all also comm key is now link with windows key instead of alt key.
Kindly use following DSDT
  https://easyupload.io/wabm9o
Edited by Dec_Bra1n
need check tutorial in voodooi2c github
I actually I followed but as per guide ACPI TPD0 should have IOInterruptSpecifiers entries but I got missing IOInterruptSpecifiers entries also i am getting IOInterruptSpecifiers entries in GPI0 which is 0e.
hi guys, i have some big issues with a dell precision 3530 and the trackpad. Atm is working with a micro input lag and some crazy movement, no way the buttons works. I'm trying to send the run me file but is too big, is like 17mb. ANy help?
post one full dump
use google drive or other service
1 hour ago, orbee said:
that's it, thanks- I had some problem with the ioreg dump, it failed 3 times
first remove these acpi renames, reboot and extract new sendme
renames stay there
