3 hours ago, Laxmi Shankar Sumankar said:
Please help me i tried many was to load kext but it's doesn't load anymore. Can you please suggest.
check kexts order
Enjoy!
Hi everyone, I try to understand the touchpad setting and I need some help on it.
I'm using a Catalina 10.15.7 with OC 0.6.6 on my DELL INSPIRON 7773 Laptop.
Almost everything working good, just find out how to get my sound back with boot-arg.
But still got this annoying message "No trackpad found". The point is, trackpad is working well,
And before my migration from Clover I had this menu fully functional.
In my ACPI folder I've got my "SSDT-XOSI.aml" so I certainly missing a part of something to get the job done.
Everything had the green light on "config checker" so...
Is there a easy way to troubleshot this Touchpad menu ?
Second point, "Energy saver" I can't tick the box "Show battery status in menu bar", is there a link ?
Thank to reading me. More pics or informations if it's needed.
With windows patch(or xosi ssdt + acpi renames) + voodooi2c kexts, after that check ioreg
I have been working on my trackpad for 48 hours now , system still does not detect it at all.( Catalina and Big Sur both)
HP ENVY 13 inch Laptop - 13-ba0010ca
I think it's HID Synaptics 2393  SYNA2393 trackpad.  I have tried everything, nothing works.
I got everything else working, just the trackpad.
Please give me some guidance , guys! thanks!
it's ice lake i5-1035G1 on HP875A board.
Edited by Mike Wilson
some synaptics u need edit synaptics plugin with "name"
use VoodooI2C.kext and VoodooI2CSynaptics.kext and edit
I have both , when I use voodool2cHID , I can see trackpad panel get actived, but trackpad still does not work.
when I use voodool2csynaptics. satalite does not get loaded , so no trackpad panel showing .
how do I edit the plugin with "name"?
can you refer me to a guide?
thanks..
for example device from my mobile is SYNA2B61 and i need edit synaptics voodoo plugin with name
I find HID\VEN_SYNA&DEV_329D&Col01 in windows.
so I put 329D in voodoo info file, but somehow, system just does not load this VoodooI2CSynaptics satellite kext..
did I do anything wrong?
VoodooI2CHID can be loaded but no device can be found ..
to quote DSDT
                If (LLess (OSYS, 0x07DC))
                    SRXO (GPDI, One)
                Store (GNUM (GPDI), INT1)
                Store (INUM (GPDI), INT2)
                If (LEqual (TPDM, Zero))
                    SHPO (GPDI, One)
                If (LEqual (TPDT, One))
                    Store ("SYNA2393", _HID)
                    Store (0x20, HID2)
                    Return (Zero)
                If (LEqual (TPDT, 0x02))
                    Store ("06CB2846", _HID)
                    Store (0x20, HID2)
                    Return (Zero)
                If (LEqual (TPDT, 0x06))
                    Store ("ALPS0000", _HID)
                    Store (0x20, HID2)
                    Store (0x2C, BADR)
                    Return (Zero)
                If (LEqual (TPDT, 0x05))
                    Store ("SYNA329D", _HID)
                    Store (TPDH, HID2)
                    Store (TPDB, BADR)
                    If (LEqual (TPDS, Zero))
                        Store (0x000186A0, SPED)
                    If (LEqual (TPDS, One))
                        Store (0x00061A80, SPED)
                    If (LEqual (TPDS, 0x02))
                        Store (0x000F4240, SPED)
                    Return (Zero)
which one is my device number? thanks. SYNA239D or SYNA3293?
I tested with both btw, still not working.
Thanks!
need check on windows or ioreg if loaded
SYNA329D
When I use this Voodoo2cSynaptics   Satellite kext with the name change , somehow it doesn’t get loaded like 2CHID  one, any insight why? It’s actually never get loaded before even without the name change.. which ssdt patch  do I still need with this kext?
thanks!
I will try again later.
u need test
some syna work with VoodooI2C.kext/VoodooI2CHID.kext and others with VoodooI2C.kext/VoodooI2CSynaptics.kext
21 minutes ago, MaLd0n said:
u need test
Do I need to do name change for VoodooI2CHID.kext as well?
with Voodoo2c with either 2cHID or 2Csynaptics, Do I still need to enable SSDT-XOSI with _OSI to XOSI (OS) fix?
if I use the DSDT you help me with, do I still need to use enable SSDT-XOSI with _OSI to XOSI (OS) fix? or do I have to load voodoo2c with satellite as well?
thanks!
