Maybe I need to remove some kexts from apple on S/L/E
YES. Remove any track pad kexts from S/L/E
Donate
Gitter Chat
MSI B360 Gaming Arctic
Could you make a ssdt for i2c touchpad (for acpi hotpatch), based on origin dsdt ?
You can re-use your ssdt-I2xx.aml for that.
Donate
Gitter Chat
Yes, but I would like to compare it with yours , to see if I did it correctly.
Second reason is that with mine ssdt I still need to use sta and crs patch on clover.
With the dsdt you sent me these doesn't needed anymore.
For SSDT to function as an "override" to DSDT, it is required for return zero.
Donate
Gitter Chat
[ref]mathewgx[/ref], This is the code for my ssdt. I dont need xcrs or xsta in clover.
Let's see if you can recreate yours ;)
DefinitionBlock ("", "SSDT", 2, "ONEM", "i2cc", 0x00000000)
   External (_SB_.PCI0.I2C1, DeviceObj)    // (from opcode)
   Scope (\_SB.PCI0.I2C1)
       Name (_STA, Zero)  // _STA: Status
       Device (TPD1)
           Name (_HID, "SYN1B7F")  // _HID: Hardware ID
           Name (SBFG, ResourceTemplate ()
               GpioInt (Level, ActiveLow, ExclusiveAndWake, PullDefault, 0x0000,
                   "\\_SB.PCI0.GPI0", 0x00, ResourceConsumer, ,
                   {   // Pin list
                       0x1B00
           Method (_CRS, 0, Serialized)  // _CRS: Current Resource Settings
               Name (SBFB, ResourceTemplate ()
                   I2cSerialBusV2 (0x002C, ControllerInitiated, 0x00061A80,
                       AddressingMode7Bit, "\\_SB.PCI0.I2C1",
                       0x00, ResourceConsumer, , Exclusive,
               Return (ConcatenateResTemplate (SBFB, SBFG))
Donate
Gitter Chat
iospecifiers still 0x33.
wont iospecifiers be tagged to your hardware?
Donate
Gitter Chat
Yes , but they are bigger than 47 so my touchpad doesn't work right
Then follow through the guide for iospecifiers larger than 0x2f
Donate
Gitter Chat
That's what I did.
Nevermind. Seems that I need _crs to xcrs patch at clover to get trackpad working right.
Added in 1 minute 35 seconds:
One more question.
Can you tell from my ioreg what type of touchpad i have ? It is synaptics?
Update: My trackpad now works with latest release!
My trackpad had a problem of not being able to use the latest kext release. And so I was stuck with release v2.0.2. Until recently, the dev replied to my GIT issue and mentioned to disable "Ignore built-in trackpad" in Sys Prefs > Accessiblity > Mouse & Trackpad
https://imgur.com/OixkqsS
And true enough, I am able to use my trackpad using the latest release (v2.1.4 as of this writing). How awesome is this?
Donate
Gitter Chat
Anybody tried to use SYNA3602 touchpad? It is a touchpad that did not work even in Linux until kernel 4.19 and 5.0 and so it does not work in Android-x86 and ChromeOS either.
check here if your device is officially supported. https://voodooi2c.github.io/#Installation/Installation
Donate
Gitter Chat
I think it is not, but I can try that guide anyway, right?
Btw, do you think it would be possible to update the images in this guide? Also the kext repo link no longer works. I think this would help a lot of people! Thank you very much.
You can try, of course.
Yeah, I'll reupload some of the missing images when I get the time soon! Thanks for the heads up.
Donate
Gitter Chat
