[ref]ahmedgamal09[/ref], Let's try polling mode and replace the kexts with the attached. Reboot and extract new sendme.
DSDT-Poll.zip
Archive.zip
Donate
Gitter Chat
MSI B360 Gaming Arctic
follow asking in the facebook.
At first I cannot boot Catalina since I got Olarila EFI folder but after intallation I still not able to use trackpad, Battery status and screen brightness. So I search from internet and modified conflig.plist.
And below is my result after running runme app. Trackpad is not usable an do not have trackpad option appear on acessibility.
Please help suggest.
https://drive.google.com/file/d/1nEnWfhvUTheBVWtSRnllR91lOI72DHVo/view?fbclid=IwAR2TzJs6Y7l4FxCIqrIG-q8Rf6I5rBJ-S3S3S7XLOebIEkBAySq940kM5QA
[ref]iamifinance[/ref], First of all, your EFI is a mess! Replace the EFI folder with this and reboot. https://Olarila.com/files/Clover.Folder/CLOVER.NOTEBOOKS.100.200.300.zip
I need your ACPI tables. To do that, at Clover bootloader, press F4 and wait for a moment. Then boot normally.
Extract new sendme files.
Donate
Gitter Chat
The EFI is unbootable stuck at the line smcLightSensor : alsd @ No iterator
Enable EC0 to EC patch in Clover.
For F4 I have no response from pressing.
You wont be able to see anything from the bootloader. But, once booted, you will find ACPI tables in Clover/ACPI/Origin folder
Donate
Gitter Chat
Where is enable EC0 patch in CLOVER ?
In CLOVER menu ?
Clover Menu> Options> Custom DSDT patches > EC0 to EC
Donate
Gitter Chat
for the Origin folder is as below
https://drive.google.com/drive/u/1/fold ... W67saFE810
and RunMe result is as below
https://drive.google.com/drive/u/1/fold ... LJ1unp_Fhh
Your files are not accessible
After change EC0 to EC. Now I can boot and Battery percent is activate but USB wifi and Screen light unusable
USB Wifi you will need OEM drivers. Install them. Screen light? IF you mean brightness slider, that can be done in DSDT patch/ clover>addPNLF
Donate
Gitter Chat
now it don't work at all
Now I see a different message in kernel.
Try this and extract new sendme.
DSDT-SBFI.zip
Donate
Gitter Chat
[ref]ahmedgamal09[/ref], Add this SSDT to ACPI/Patched folder and reboot.SSDT-I2C0.aml.zip
Like I had previously mentioned, you might also want to read post 2 on getting gpiopin. Your iointerruptspecifier is 0x50.
Donate
Gitter Chat
you need to add your trackpad device name in synaptic kext. And you also need to patch your _Crs return correctly
Added in 30 minutes 54 seconds:
You have had multiple OSI patches but did not patch the latest.
Only latest OSI emulation.
https://imgur.com/rRgO2Gq
Brother, my notebook was stolen, but thank you for help me
HahAhAH
I read about it in your other post! This is outrageous! I feel sad for you.... :(
Donate
Gitter Chat
Hi onemanosx,
with last DSDT touchpad work.
IOReg shows trackpad fully loaded in polling mode.
Donate
Gitter Chat
