trackpad option came after installing ACPI battery manager kext
good to know! I was also reading about it earlier. Congrats!
[ref]broadw3ll[/ref], fyi
Donate
Gitter Chat
MSI B360 Gaming Arctic
[ref]broadw3ll[/ref], implement your battery status and see where that will lead you to. The same info is also given to me by one of the regular community at voodooI2C gitter.
Donate
Gitter Chat
Hi @onemanosx
Great guide.
However i tried it but it doesn't works at all.
The Device is ETPD and it shows in IOReg. But no Trackpad. Let me know what files you need.
Also, i added the CFL controllers to VoodooI2C info.plist
[ref]Striker770[/ref], You did not patch your DSDT for working I2C.
This is what I found out for your ACPI table
- IOInterruptSpecifiers is 0x5f (more than 0x2f) you are required to follow steps outlined in post 2
- 0x5f is equivalent to pin 47 (read guide in post 2)
Try boot with attached DSDT. (You may need to rebuild permission and cache upon first boot and reboot again)
1109420218_Screenshot2018-12-30at10_19_39PM.thumb.png.db7550d77abc3e654ab695e5e5ececdc.png
Donate
Gitter Chat
That's absolutely correct. It was unpatched. When you asked for files, i patched my DSDT for the same and that caused the delay. But still, it doesn't works. Moreover, the ETPD disappears after this.
Have you rebuild cache and repair permissions?
If problem still persist, go to dev site for support. The kexts are still buggy I think. For instance, I am not able to use kexts newer than v2.0.2 in High Sierra or Mojave, and the dev is not able to solve that yet.
Donate
Gitter Chat
I've rebuilded the permissions. But no luck.
I've been using v2.1.4 in HS, Mojave and works like a charm. But this is new Laptop and it's Coffee Lake and i'm unable to make the Trackpad working.
They're not helpful at all. Been there for 3 months. No help yet.
Try these kexts. Use original DSDT or my patched DSDT. I need to see ioreg on both DSDT used.
Archive.zip
Donate
Gitter Chat
Works fine but I would like to know your opinion.
My opinion doesnt count LOL I am not even an expert. But your ssdt is doing its magic as expected. Did your write the SSDT-i2c yourself?
Donate
Gitter Chat
[ref]Striker770[/ref], I think your issue is with your device support. VoodooI2C do not support your device id. Did you try the modded kexts I had uploaded? Also, what you can try is also to replace the pin from 0x47 to 0x00 from my patched DSDT and return status to 0x0F for device ETPD.
And upload a copy of IOreg for troubleshoot purposes.
Added in 2 minutes 5 seconds:
I would like to have only the ssdt for i2c without the need for the sta and crs patches on config.plist.
Good job on that! I will troubleshoot for mine and see if that will help me get out from being stuck at v2.0.2 kexts.
Edit: Looks like I am stuck at old kexts until the dev does something about it.
Donate
Gitter Chat
[ref]Sireens[/ref],
Kext is loaded and well. Try the DSDT.
Didn't work :( . Maybe I need to remove some kexts from apple on S/L/E
