I did not find any improvements ...
Lets try Interrupt mode and see if situation improves.
DSDT-Interrupt.aml.zip
Reboot and generate new send me files.
Donate
Gitter Chat
MSI B360 Gaming Arctic
The touchpad worked fine, but the settings do not open
I dont understand what you mean by settings do not open. No sendme file.
Donate
Gitter Chat
[ref]zzmagus[/ref], Trackpad preference settings are dependant on battery indicator patch.
1. Disable these 2 patches.
https://imgur.com/vzrnYms
2. Also, you do not need these SSDT as your DSDT is already full patched. Delete these 2 SSDTs. Your Batt SSDT is most probably conflicting with DSDT causing the preference setting not to appear.
https://imgur.com/qrOvmuQ
3. Clean up your kext folder. You do not need these 3 kexts.
https://imgur.com/sRTf9d3
Donate
Gitter Chat
did not help
Send me MacBook-Pro-kust.zip
[ref]zzmagus[/ref], Sorry. No idea. By default, track pad settings will appear with battery patch. And your battery patch is clearly working.
Donate
Gitter Chat
@onemanosx ,
can you help me to patch my trackpad?
Thanks in advance.
Add these patches in config:
<dict>
				<key>Comment</key>
				<string>change _STA to XSTA in Device GPI0 </string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				X1NUQQ==
				</data>
				<key>Replace</key>
				<data>
				WFNUQQ==
				</data>
				<key>TgtBridge</key>
				<data>
				R1BJMA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>change _CRS to XCRS in Device TPD0</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				X0NSUw==
				</data>
				<key>Replace</key>
				<data>
				WENSUw==
				</data>
				<data>
				VFBEMA==
				</data>
			</dict>
SSDT-I2C.aml.zip
Donate
Gitter Chat
unable to activate on lenovo ideapad320 15IKB ( define GPP_C15_IRQ 63. 0x3F)
Maximus VIII Ranger/ RX 580/ i56600k/ Ram 16G 1600
Lenovo IdeaPad 320 15IKB
Attach send_me dump files
RunMe
Donate
Gitter Chat
[ref]neverday[/ref], Replace Clover folder. Reboot. Extract new Send_Me.
CLOVER.zip
Donate
Gitter Chat
[ref]neverday[/ref], extract Origin Folder. Need native ACPI table.
Donate
Gitter Chat
[ref]neverday[/ref], Looks like it does boot.
Anyway, here is what I need you to do next as there is a report of voodooI2CHID kext not loading.
1. Download new voodooI2C and voodooI2CHID kexts from here https://github.com/alexandred/VoodooI2C/releases
2. Place both kexts in clover/kexts/other
3. Open Terminal and Type
sudo kextcache -i /
4. Reboot.
5. Generate new sendme.
Donate
Gitter Chat
[ref]onemanosx [/ref], Tanks Touchpad active, Gestures not active!
https://mega.nz/#!Hsd2AYwJ!xMdu751qqDm7JESQ56KrIfZH2lrxAoGbNEMS7W9VkSs
What do you mean by gestures not active? Trackpad perfpane?
1. I have updated your DSDT. Use this and remove old one. DSDT.aml.zip
2. Try this kext. Place in Clover/kexts/other and remove voodooI2CHID kext. VoodooI2CSynaptics.kext.zip
sudo kextcache -i /
Reboot.
Donate
Gitter Chat
