xWeasel Posted December 15, 2018 Posted December 15, 2018 Hi, yesterday I downloaded the 10.14.2 update and installed it. Everything went well, but after it displayed a message related to "restart to finalize changes", I restarted but Clover now doesn't want to boot up at all. I didn't change the boot priority at all and I have no idea why it doesn't want to boot up anymore, considering it was working fine before. By the way, I use a USB to boot up macOS (once Mojave starts working again, i'll put Clover on my SSD). The weird this is that when I put that same USB inside another computer and it booted up fine. Can someone please help me? Thank you. EDIT: When I load up the USB that has Clover on it, i'm stuck on a black screen with a mini horizontal line in the top left corner.
Administrators MaLd0n Posted December 15, 2018 Administrators Posted December 15, 2018 try with nv_disable=1, check if work -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
xWeasel Posted December 15, 2018 Author Posted December 15, 2018 try with nv_disable=1, check if work Could you please tell me where I can find that option? Can't find it anywhere. Thanks!
erroruser Posted December 15, 2018 Posted December 15, 2018 [ref]xWeasel[/ref], you add nv_disable=1 to the boot args AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler
xWeasel Posted December 15, 2018 Author Posted December 15, 2018 [ref]xWeasel[/ref], you add nv_disable=1 to the boot args Ohh ok, thank you! try with nv_disable=1, check if work Tried that now but still no luck :/
erroruser Posted December 15, 2018 Posted December 15, 2018 [ref]xWeasel[/ref], if your using mojave with a gtx 780 will not work youll have to use amd cards or have a metal supported gpu kepler or fermi as there are no web drivers supported AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler
xWeasel Posted December 15, 2018 Author Posted December 15, 2018 [ref]xWeasel[/ref], if your using mojave with a gtx 780 will not work youll have to use amd cards or have a metal supported gpu kepler or fermi as there are no web drivers supported Yes I understand that but before the update, Mojave was working perfectly with my GTX 780 (it even showed up when I clicked About this Mac). Oh I forgot to mention that clover boots up normally on another PC but it just doesn’t boot up on my main PC. Thank you for the help. EDIT: nevermind, I mentioned it in the post. My bad.
xWeasel Posted December 16, 2018 Author Posted December 16, 2018 I FINALLY got it to boot up!! But I got another problem..... my SSD that Mojave is installed on is not showing up. I thought putting in the APFS EFI would fix it but it didn’t work. Any ideas?
Allan Posted December 16, 2018 Posted December 16, 2018 Try use the ApfsDriverLoader.efi Thanks & Regards IdeaPad Gaming 3i • Aspire A515-52 • Clover / OpenCoreWe are in a great Forum, so, let's have some fun and learn from each other!
xWeasel Posted December 16, 2018 Author Posted December 16, 2018 Try use the ApfsDriverLoader.efi Thank you! I reinstalled it and now it shows up! But another problem..... once the loading bar fills up, it stays there for around 2-4 mins. After that I get a black screen. Same issue when trying to boot into safe mode. EDIT: in verbose, it says busy timeout[0], (60s), “AppleACPICPU”
Allan Posted December 16, 2018 Posted December 16, 2018 Which boot-args are you using to boot? Thanks & Regards IdeaPad Gaming 3i • Aspire A515-52 • Clover / OpenCoreWe are in a great Forum, so, let's have some fun and learn from each other!
xWeasel Posted December 16, 2018 Author Posted December 16, 2018 Thank you everyone for the help! I stupidly forgot to put in the kext files inside the correct folder. After I did that, it’s perfectly running 10.14.2!
onemanosx Posted December 16, 2018 Posted December 16, 2018 forgot to put in the kext files inside the correct folder. After I did that, it’s perfectly running 10.14.2! Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
