Bluetooth Problem In Mojave 10.14
Hello, Guys, I have a problem with my Bluetooth...
my problem is that when I turn on "boot" my mac the Bluetooth does not appear in the system preferences! means do not recognize by the OS!
but if I restart "reboot" my mac then Bluetooth will appear in the system preferences and works perfectly!
so I'm asking about a solution it because I do not want every time boot and reboot my mac to make my a Bluetooth works! here is my files thanks.
Send me Dahens-MacBook-Air.zip
1164044350_ScreenShot2018-12-11at11_31_52PM.thumb.png.834beb92407fb09712a7719c73e28dda.png
1109833520_ScreenShot2018-12-11at11_33_19PM.thumb.png.429d01c3c1f0987c6cfd69f804b070d7.png
What Chip u using? If u using extrnal usb blutooth it's not showing there :guitar
I don’t use external chip!
I use on board Bluetooth..
My laptop is Lenovo Z50-70 core i7..
[ref]DahenECE[/ref], its possible that the wifi/bt chip is not compatible if intel, some atheros are not supported an the broadcom have better support you can read here also on the kexts needed for bluetooth https://hackintosher.com/forums/thread/enabling-third-party-broadcom-wlan-802-11a-b-g-n-wifi-bluetooth-cards-on-a-hackintosh-bcm94352z-bcm94322.6/
:superman:superman
its working partially then its not stable bro no use for that then u replace bcm chip its best way for u
