[GUIDE] How to Activate Microphone on Conexant Codecs and others.
[ref]nikhilrathore_1999[/ref],
Without your codec_dump I can't fix anything.
codec dump is in the link that i gave you above (through runmeApp
Added in 1 minute 37 seconds:
where did i get this codec dump??
Hi [ref]Mirone[/ref]
Good Day. I'm having trouble making my earphone mic via combojack work.
I have tried this fix and It does fix the popping and distorted sound on my hack when coming from sleep but still no mic via inline(combojack)
I have ALC255 and I am using AppleALC.
I have also tried creating my own layout & platform (layout id = 26) for AppleALC.
Internal Speaker, Internal Mic & Earphones do work but external mic via linein(combojack) does not work.
Kindly see attached file for my files that you can check. Hope you have some time checking into my issue. Thank you
Regards,
John
report_files.zip
basically please fix the audio fully for my laptop
Sorry for the delay, Honestly I don't have time to patch AppleHDA unless I get paid for it, anyway follows the files.
Archive.zip
Added in 10 minutes 40 seconds:
Try the same files above.
use Layout-ID=3
Archive.zip
use Layout-ID=3
Hi [ref]Mirone[/ref],
I have tried the AppleALC you posted and using layout id 3, I only have speaker and headphone working. Internal Mic does not work now but its recognized also inline mic via combo jack does not work. What can I send now to help? Thank you for your time
Archive.zip
use Layout-ID=3
small issue when i connected to headphone jack than mic didn't change from internal to LineIn can u fix??
Added in 17 seconds:
Archive.zip
use Layout-ID=3
