[GUIDE] How to Activate Microphone on Conexant Codecs and others.
[ref]Sampath007[/ref], please try this aDummy.kext + Jack_Fix in Mojave use layout-id=2.
Bro sorry for late Replay i tried this kexts sle and others folder too and i injected id 2 in config.plist its not work then i removed dsdt audio patch then sound gone :wallbash
i tryed bro its not work then i replayed that time but my replay not here
Hi, I have Realtek ALC294, I managed to have speakers sounds both with AppleALC and VoodooHDA. I can't get Headphones audio to work. This fix could work for my configurations? How do I apply it? Thanks.
EDIT: Ok, my fault, fix for headphones it's Jack_fix, Thanks!!
Great topic [ref]Mirone[/ref], im have issue with my Conexant too. Maldon help me a lot, and Jake Lo too, but only work with your AppleHDA full patcher. When im put AppleALC works the sound, but mic external and internal not... :D
But im try too your post above, and im know Amit from EliteMacx86.com and its a good guy!!!
Are you recommend try something or not? Maldon edit my config.plist and DSDT from Lenovo Thinkpad E470.
(Valeu [ref]Mirone[/ref], por toda sua ajuda, apenas hoje que vi seu post de retired do Insanely :| )
Gigabyte Aorus Z790 Elite AX / Raptor Lake 13th Intel® Core™  13900K / AMD AORUS RX 6900 XT  2 rev. / Lenovo E470 i5-7200-U Kaby Lake iGPU intel HD620 64 GB Ram / ASUS Prime B365M-K Desktop intel i3-Coffe Lake / ASUS Sapphire Nitro+ AMD RX 580 4GB / Gigabyte B360 i5-Coffe Lake / RX 64 Vega OC Gigabyte / Gigabyte B660 Raptor Lake 13th Intel® Core™ i7-13700K  / Nvidia GeForce GTX 3060 Gainward 12GB /  Gigabyte Z170 XP SLi  Intel® Core™ i7  iGPU /  Mac mini M4 Pro 12/16  24 GB Ram  512 GB Nvme /   MacBook Air 2020 10th Ice Lake Intel® Quad-Core™ i7-1060NG7 T2  Iris Plus Graphics  /  Clover Hacky Color 5161  / Opencore 1.0.4 /  God Bless you!
[ref]Mirone[/ref],
So many thanks my brother!!!
Valeu meu caro!!! :D
(files was deleted because the codec dump was in nexts posts...)
Sorry Mirone, im not know what's happens, im will try again...
Im will try with ubuntu iso live...thanks sorry!!!
[ref]Mirone[/ref], my friend!!! Sorry im noob about it, im get codec dump with Ubuntu distro.
Here the files, so many thanks!!!
:mrgreen:
Lenovo codec dump DSDT config plist 2.zip
[ref]max.1974[/ref],
1- Install AppleHDA in: /System/Library/Extensions (Use Olarila Repair Permissions)
2- Copy and paste CodecCommander to: EFI ▸ CLOVER ▸ kexts ▸ Other
3- copy the Jack_Fix folder to your Desktop and run Install.command
4- Repair the permissions and rebuild the caches (Use Olarila Repair Permissions)
Lenovo Files.zip
:D Olá Mirone, deixa eu explicar pois meu inglês não é tão bom...kkk
Meu brother, eu usei seu programa e obtive a AppleHDA perfeita, mas tem que instalá-la a cada update, então lendo seu post, me perguntei seria o caso do Mirone obter a AppleALC ideal para que eu não precise modificar a AppleHDA ?
Quero agradecer de coração sua ajuda, e queria saber se é possível obter a AppleALC para o meu caso, ou apenas a AppleHDA?
É porque instalei a que seu programa me forneceu e está funcionando o microfone, porém só funciona com a AppleHDA sem a AppleALC na pasta other. Ok?
Obrigado mesmo e peço mais esse favor de informar, e não irei me esquecer de seu trabalho, ok? :guitar
Obrigado Mirone!!! Valeuuuu!!!
Mirone!!!
Obrigadoooooooooo!!!!!!
Funciona muuuuitooooooooo bemmm!!!
Excelente trabalho meu caro, Deus abençoe!!!!!!!!
Cara que demais, não tenho nada além do config.plist e do DSDT e sua AppleALC!!!!
Fresh install que tava coçando pra arrumar o áudio!!! Só esperando sua baita ajuda!!!!
Vc merece sempre saúde e paz irmão, e reconhecimento!!!!
Obrigadoooooo!!!
:guitar:guitar:guitar:superman:superman:D:D:D:frantics:frantics:meeting
1995266436_CapturadeTela2019-03-05s01_50_30.thumb.png.fc34808f5b66df2a5e1962c1a69f8110.png
Mirone!!!
Obrigadoooooo!!!
Show, Obrigado pelas energias positivas, tudo de melhor!
energias positivas
tá precisando :mrgreen::meeting
Valeu MaLD0n meu brother... :guitar:meeting:D
