M0001 Posted November 25, 2018 Posted November 25, 2018 Any suggestions on where to start with why Ethernet goes on / off? ... it was working, I swapped some non-boot drives out, rebooted and it cycles on the ethernet now. It starts cycling once the kext loads. If I boot into some other OS it works.
Administrators MaLd0n Posted November 25, 2018 Administrators Posted November 25, 2018 extract one dump RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
M0001 Posted November 25, 2018 Author Posted November 25, 2018 The status will go between: "The Cable for Ethernet is connected but your computer does not have an IP address" or "Either the cable for the Ethernet is not plugged in or the device at the other end is not responding" BIOS settings of "Wake on LAN" either disabled/enabled matter not. Send me ICBM-20.zip
Administrators MaLd0n Posted November 25, 2018 Administrators Posted November 25, 2018 [ref]M0001[/ref], try delete files in this folder, delete connection too, reboot and create again -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
M0001 Posted November 25, 2018 Author Posted November 25, 2018 Same result, except the computer name changed .. (of course) Send me iMac-Pro.zip
Administrators MaLd0n Posted November 25, 2018 Administrators Posted November 25, 2018 [ref]M0001[/ref], take one shot, try without DSDT after test without DSDT use it DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
M0001 Posted November 25, 2018 Author Posted November 25, 2018 No change when I removed DSDT.aml from ACPI/Patched. Replaced it with the one provided above, still the same. I also plugged in a Belkin USB-C ethernet dongle. I don't get the "bouncing", I can set an IP manually but it still does not work. Added in 4 minutes 49 seconds: Without the interface defined, if I plug in the cable, the link remains solid. As soon as I add en0 and apply it, the link status starts cycling between cable is plugged in, self assigned IP, cable is unplugged, repeat. It does the same thing with both ports, and acts similarly with USB ethernet.
Administrators MaLd0n Posted November 25, 2018 Administrators Posted November 25, 2018 [ref]M0001[/ref], is a very strange -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
erroruser Posted April 7, 2019 Posted April 7, 2019 try this go to /Library/Preferences/SystemConfiguration/ an delete NetworkInterfaces.plist then empty trash repair permissions an reboot hope this help you AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler
