Hi! I downloaded the Olarila image and burnt it with etcher on my old Mac. I get this screen and then it doesn't do anything else (apparently) ct9Tc0 . Can anybody help me, please?
[ref]Lovecraft[/ref], last bios version?
[ref]Lovecraft[/ref], update bios for last version
the version is American mega trends 1.40, October 2018. I don't know how to update it...but this should be the last version
Added in 1 minute 27 seconds:
because I downloaded msg live update and it didn't change that
[ref]Lovecraft[/ref], Strange
what Olarila image u use?
Ok, downloaded the version from the link you gave me (its in a poste from August 21st, the one which says FINAL). Uncompressed it with 7zip, burnt it in a usb stick with win32 and reboot. F11, install Mojave from the usb... same problem. It is sticker st the same point
Added in 37 seconds:
Stopped
[ref]Lovecraft[/ref], no idea, other user report if use old bios version work, u can try
