Amazing! I can use now my Laptop Trackpad, I have to press it to clic and 2 fingers press for double clic but it's working!! Thank you brother. Can you help me with battery status?
Place my DSDT in ACPI/Patched folder and use my config.plist. reboot and generate new send me files. Your last sendme is missing my DSDT and config.plist.
Donate
Gitter Chat
MSI B360 Gaming Arctic
[ref]juanjor87[/ref], Replace DSDT and check for battery status and track pad
Donate
Gitter Chat
In wich folder should I have to paste it? ACPI/origin or ACPI/patched?
ACPI/Patched of course. Replace the old DSDT.
Donate
Gitter Chat
It doesn't work, actually track pad isn't working now with this DSDT.
Try again with this. Seems, your track pad don't work in interrupt mode.
Generate new send me. Thanks.
Donate
Gitter Chat
Use back the previous DSDT. Seems, your track pad don't work in interrupt mode.
But before you change DSDT, please upload IOREG copy. Thanks.
Here it is https://mega.nz/#!iAwGHSoB!H-k257BvqROf3U4Acsztk9LeECA0bDh2HnWSvJHKl3c Now I'm going to replace DSDT
Added in 13 minutes 23 seconds:
Same results as CLOVER folder. Can't place battery status at the top bar and trackpad works but clic only work by pressing.
Can't place battery status at the top bar and track pad works but clic only work by pressing.
No idea with battery, maybe some codes I have not encountered before. Just use track pad in polling mode. No idea about the single click, though.
Donate
Gitter Chat
Look at this post. I see the repo mentioned there but I don't have idea what to do
https://www.insanelymac.com/forum/topic/336796-mojave-10141-on-lenovo-330s/
Yep, I'm using the trackpad by pressing for songle click and 2 finger pressing for right click.
Added in 15 minutes 3 seconds:
I got some news! I tried that DSDT file on that post, now the battery is working correctly and the trackpad is working but pressing to click and 2 finger pressing for right-click. I'm happy =)
:mrgreen:
DONE!!! :D I'm using all files on that post, everything is working correctly, even non-pressing click is working and battery too! Thank you, bro. I owe you one!
Estou com um lenovo 330s i7 8550U GPU Intel 620 + AMD Radeon 535, não consegui fazer funcionar o touchpad e o status da bateria, também não funciona o AMD Radeon 535 alguém pode ajudar? :|
[ref]diegoazevedo[/ref], deve ser tipo optimus technology, a amd não funciona, vai ter de desativar e usar a IntelHD
cara obrigado pela resposta, eu imaginava isso, agora o touch e bateria alguma sugestão?
[ref]diegoazevedo[/ref], veja na minha assinatura, useful links
