Issue on Sony Vaio VPCEJ14FX under Lion 10.7.2
Hello,
I just install Lion on my Laptop Sony Vaio model VPCEJ14FX.
http://imageshack.us/photo/my-images/585/sonyvaiovpcej14fxlion10.png/
You can see the picture. I use many kexts and many hour in order to get a little stability on my Laptop.
But I Know is not 100% functional. The performance is not very good. Video is very slow.
My intel HD 3000 is recognized but only with 64 MB.
I need your help.
I need a perfect dsdt.aml for my system. I get the DSDT un windows with you tools. But I am unable to edit or patch.
Here I am uploading my dsdt.aml and report system, I need you help me to fix this DSDT in order to do my system work in perfection. I need activate the audio too.
I add a little USB dongle Bluetooth and is working. I am working with a genuine Apple Magic Trackpad.
Help me please, fix my dsdt.aml, and let me get the 100% performance of my system.
Now if you need i install lion again, there is not problem.
Your are the teachers I am the student.
Thank you.
DSDT_plus_reporte_vaio_VPCEJ14FX.rar
Ok, I just install again Lion 10.7.2 on my Sony Vaio VPCEJ14FX.
A clean installation, I use DSDT with core i sandy Bridge patch, plus dualink, I use multibest for it, system utilities + Macbook Pro 8,1. Plus apply the Speedstep patch.
FOr audio I use VoodooHDA kext. The audio is great, I apply ID device.
I reboot the system and I get this panic: com.apple.driver.AppleIntelCPUPowerManagement. (See the picture please).
Plus, please can you check my DSDT in order to see all is well o apply some patch for.
I will try to install again when you let me know from you.
Ok, thank you very much.
DSDT.zip
Did you use the correct speedstepper version?
Did you enable "generate P and C states" in Boot.plist?
Patches look right.
OK, I go again, 15 minutes.
I will go to apply all the patch,
But, you said "Did you enable "generate P and C states" in Boot.plist?" How I do it? On multishit or with other bootloader. If you have a best one option let me know.
I am instaling Lion again.
I will looking for you.
Thank you
My Report under Windows:
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
Computer Type ACPI x64-based PC (Mobile)
Operating System Microsoft Windows 7 Home Premium
OS Service Pack Service Pack 1
Internet Explorer 9.0.8112.16421 (IE 9.0)
DirectX DirectX 11.0
Computer Name LUIS-VAIO
User Name Luis
Logon Domain Luis-VAIO
Date / Time 2011-11-02 / 15:51
Motherboard:
CPU Type Mobile DualCore Intel Core i3-2310M, 2100 MHz (21 x 100)
Motherboard Name Sony VPCEJ14FX
Motherboard Chipset Intel Cougar Point HM65, Intel Sandy Bridge
System Memory 4043 MB (DDR3-1333 DDR3 SDRAM)
DIMM1: Kingston SNY1333D3S9ELC/4G 4 GB DDR3-1333 DDR3 SDRAM (8-8-8-22 @ 609 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz) (5-5-5-14 @ 380 MHz)
BIOS Type Insyde (04/28/2011)
Display:
Video Adapter Intel® HD Graphics Family (1841080 KB)
Monitor Generic PnP Monitor [NoDB]
Multimedia:
Audio Adapter Conexant Cx20590 @ Intel Cougar Point PCH - High Definition Audio Controller [b-2]
Audio Adapter Intel Cougar Point HDMI @ Intel Cougar Point PCH - High Definition Audio Controller [b-2]
Storage:
IDE Controller Intel® Mobile Express Chipset SATA AHCI Controller
IDE Controller Realtek PCIE CardReader
Disk Drive ST9500325AS (500 GB, 5400 RPM, SATA-II)
Optical Drive DTSOFT Virtual CdRom Device
Optical Drive Optiarc DVD RW AD-7710H (DVD+R9:6x, DVD-R9:6x, DVD+RW:8x/8x, DVD-RW:8x/6x, DVD-RAM:5x, DVD-ROM:8x, CD:24x/24x/24x DVD+RW/DVD-RW/DVD-RAM)
SMART Hard Disks Status OK
Partitions:
C: (NTFS) 455.3 GB (283.2 GB free)
Total Size 455.3 GB (283.2 GB free)
Input:
Keyboard Standard PS/2 Keyboard
Mouse Alps Pointing-device for VAIO
Network:
Primary IP Address 192.168.1.###
Primary MAC Address 90-00-4E-C6-A7-66
Network Adapter Atheros AR9285 Wireless Network Adapter (192.168.1.111)
Network Adapter Realtek PCIe GBE Family Controller
Peripherals:
Printer Enviar a OneNote 2010
Printer Fax
Printer Microsoft XPS Document Writer
USB2 Controller Intel Cougar Point PCH - USB EHCI #1 Controller [b-2]
USB2 Controller Intel Cougar Point PCH - USB EHCI #2 Controller [b-2]
USB Device Generic USB Hub
USB Device Sony Visual Communication Camera
USB Device USB Composite Device
Battery Microsoft AC Adapter
Battery Microsoft ACPI-Compliant Control Method Battery
Battery Microsoft Composite Battery
DMI:
DMI BIOS Vendor INSYDE
DMI BIOS Version R0180Z9
DMI System Manufacturer Sony Corporation
DMI System Product VPCEJ14FX
DMI System Version C105PLDM
DMI System Serial Number 27544732-3002875
DMI System UUID A0D1373A-1DF6DE11-88227884-3CE360C7
DMI Motherboard Manufacturer Sony Corporation
DMI Motherboard Product VAIO
DMI Motherboard Version N/A
DMI Motherboard Serial Number N/A
DMI Chassis Manufacturer Sony Corporation
DMI Chassis Version N/A
DMI Chassis Serial Number N/A
DMI Chassis Asset Tag N/A
DMI Chassis Type Notebook
I use Chameleon Wizard to configure http://Olarila.com/forum/viewtopic.php?f=9&t=398
If you use kernelcache, run this in terminal to update cache after you run speedstepper
I do, I am happy, Wow!!!!!!!!
Thank you very much.
Now I need enable the Wifi
Atheros AR9285 (168c-002b)
(In order to get mobility)
I have a problem with "About This MAC"
Plus problems memory information
(I have one kingtone and other samsung)
I am working on battery right now, plus the audio.
Try this patch http://Olarila.com/forum/viewtopic.php?f=17&t=391&start=40#p3731
If it doesn't work, try this
http://nawcom.com/osx86/files/10.6/Wireless/Atheros/AtherosWiFiInjector.kext.zip
For "about this Mac" crash try kext SMBIOSEFI (it's in build/Release folder)
http://www.mediafire.com/?o0mpbdam7c3mba3
SMBIOS info is hardcoded in the kext, so if you want to change it you have to edit source code and compile again (need Xcode).
Memory info can be edited in Chameleon Wizard (SMBIOS tab).
Ok, I have audio, battery, bluetooth, time machine, Keyboard PS2 is working, Trackpad is dead [Here maybe you have any idea] and with the wifi injector I get the WIFI. But here in the WIFI I get one issue, I can see networks around, but I cannot connect. A "error" dont permit to connect. I write the password, ENTER, and the Error appear.
Error in Wi-Fi. (Atheros AR 9285 / 168c-002b)
If you know about, let me know please.
Plus when the system boot I need plug a keyboard USB in order to complete the boot. Lion ask me a keyboard.
Thank you.
What's the trackpad vendor? (Synaptics, ALPS, Elantech) Try to find a specific PS/2 kext.
For wifi try this one
http://www.osx86.net/downloads.php?do=file&id=1279
About keyboard, USB should be needed only in first boot. If you are talking about the bluetooth keyboard warning, just turn it off in bluetooth preferences (advanced).
Ok, I am working on my MacBook Pro 8,1 Sony Vaio Model VPCEJ14FX.
NO WORK:
Only the ALP Trackpad. I try with many kexts. No work!
All the other components are working very fine.
Thank you for all.
When I install lion, my trackpad work. For me is not necessary the special gesture. I only want the trackpad workFor example is the battery dead in my "Magic Trackpad Of Apple" maybe I need use the trackpad of my laptop for basic operations.
The Laptop is working lika a original Lion, is fast, performance, the gesture in my "Original Apple Trackpad" work in perfection.
I only need know how I do in order my trackpad work like under the installation.
You have idea.
How do you boot the installation? There's a working kext on that volume. If it's inside an Extensions.mkext, use Kext Wizard to "unpack".
I use multishit, DSDT, System Utilities, MacBook Pro 8,1, boot with Chimera 1.6.0
Ok, I will looking for in order to get the mouse trackpad of my Laptop work.
Thank you.
Guys can you help me to install Mac OS X Lion on Sony Vaio VPCEG25EN.
My specs are almost same as yours but processor is different, it's i3 2330M.
Will you please tell me how did you managed to install Lion on your Vaio?
Please tell me with full detail of every step you followed and attach your fully working DSDT.aml file too.
I have tried unishit, iBoot legacy+multishit, iAtkos S3 V2, iAtkos L1, iAtkos L2 methods with no success, even I can't reach to the installer screen.
Please, help me guys :(
You are my only hope now.
My specs are:
i3 2330M 2.2 GHz
Intel HM65 Chipset (Sony Vaio Motherboard)
Intel HD3000
4GB DDR3 RAM
320GB HDD
