Blinking screen issue [10.13/10.14/GT730]
Hi !
So I have an issue with my hackintosh (that makes it unusable, really)
It's that the screen will go black for like 1/2 seconds every 5 minutes or so (depends, sometimes it can go as far as 5 per minutes)
I found a video showing the issue (not mine, but that's exactly the same thing that's happening to me)
SPECS:
DELL Optiplex 7010 Mini Tower
Intel Q77 Chipset
Intel Core i5 3570@3.4GHz
Gigabyte GeForce GT 730 2GB GDDR5 REV 2.0
12GB DDR3 1600MHz
macOS High Sierra 10.13.6
Someone pointed out it could be a power issue, but I really don't think it's that, even tho the power supply recommandation for the GT 730 is 300W, and the Optiplex PSU is 275W, the power supply recommandation is really often overkill (275W = 77W i5+25W GT 730+2 SSD and 1 HDD, doesn't make 275W)
And if It was, I would have the same issue on Windows when gaming, fair enough ? I don't ! I can play GPU intensive games (relatively speaking, we're talking about a GT 730 lmao) for HOURS with no problem, my PC is almost running 24/7, and no issue what-so-ever on Windows.
I tried both with Mojave and High Sierra (I'm posting in High Sierra 'cause that's what is actually installed on my SSD, but I'll probably use Mojave if I get to fix it) but no matter what, it does the same thing, and also, I think it's important to say that I had the EXACT same issue on my Dell Optiplex 780 (Core 2 Duo), so I believe that's a driver issue
I tried with both OS X driver and NVIDIA Web Driver, it does the same thing, but with the webdriver, I don't have working HDMI audio (oddly enough)
I'm using the latest version of Lilu+WhatEver Green, here's my CLOVER folder: https://drive.google.com/open?id=1Z9Sgj1g6UdNrcBzgZgrGZKsPaXr5LJ5g
Let me know if you need me to run "RunMe.app", I'm actually posting this from Windows 10, since macOS is unusable with that problem)
Okay, so I think that's it
I already posted this on InsanelyMac and OSXLatitude, but I didn't got much help from there, I hope I'll have more luck here :)
Thanks a lot to everyone who will take the time to help me with that :D
18 years old - French - TEKNO - FREE PARTY
Laptop: MacBook Pro 13" Mid 2012 - Intel Core i5 3210M - Intel HD 4000 - 12GB DDR3-1600 - 240GB SSD - macOS Catalina 10.15.2
Media Center: Mac Mini Late 2009 - Intel Core 2 Duo P7550 - NVIDIA GeForce 9400 - 8GB DDR3-1066 - 240GB SSD - OS X El Capitan 10.11.6
iPhone 7 - iOS 13.3
[ref]KFantomas[/ref], u use last WEG kext?
Yes, and I also use the latest version of Lilu
iPhone 7 - iOS 13.3
[ref]KFantomas[/ref], check in insanelymac if have solution for it
i don't use more nvidia cards
I already posted a message on InsanelyMac, no replies
But that's okay, maybe other poeple in this forum might have a solution x)
iPhone 7 - iOS 13.3
[ref]KFantomas[/ref], :guitar
