Help Installation High Sierra and NVidia GTX960 in Asus P8Z77-V Premium
Hi everyone, I have a PC with the following configuration:
motherboard P8z77-V premium
CPU I5-3470
Ram 8gb
Hdd 500 gb
Nvidia GTX 960 4gb video card
I thanks to some guidance and suggestions I managed to install high sierra.
Right now the installation is incomplete because I can not make the NVidia GTX960 4GB Ram properly work the video card
Would anyone be kind enough to help me install high sierra clean and fully functional?
Thank you so much for everything
post full dump
RunMe.app
[ref]daltanious78[/ref],
[ref]daltanious78[/ref], DSDT.aml.zip
Hi all I put the file "aml" in the folder "EFI/CLOVER/ACPI/Patched" exactly as explained on another forum ... but the problem described in the first post remains.
how should I enter the aml file correctly and what else can I do to fix it?
Hello everyone, I used the file posted to install or update the webdriver but tells me that they are already updated installed and updated for this version of high sierra .. this is the screen that appears to me when I start the hyacinth with webdrivers and since there are also the efi folder of my hackintosh.
This link is image of error: https://www.flickr.com/gp/34773431@N05/89497i
this link is my EFI Folder:https://drive.google.com/open?id=15aTTWdnSvBL7TbtZ5NCmgqBE4zCUwcx9
Thank you for all
[ref]daltanious78[/ref], the problem is nvidia driver, try with other version
hi all, what do you think is the most suitable version of webdriver to run my video card? and especially if high sierra tells me that webdrivers are not suitable and therefore does not allow the installation as I could solve the problem?
[ref]daltanious78[/ref], i made some installs everyday and i don't have problems with web driver in High Sierra
[ref]daltanious78[/ref], i'm using RX 560, RX580 or VEGA, real native support, just avoid XFX cards
[ref]daltanious78[/ref], problems
[ref]daltanious78[/ref], gtx960 don't work in mojave
Hi all, I installed an old version of webdrivers hoping to solve the problem but the card does not work yet.
Once installed the webdriver asks me to restart the hackintosh and so I do however on restart I find myself a screen that tells me that the system has some problems and lists errors ... maybe they can be useful to understand where I'm wrong so I did a copy / paste of the errors in textedit and I have exported the file as pdf..che attached to this post.
I hope you can help me.
Thanks for everything
Report Error.pdf
