Will Mojave work with this system?
Hi All,
New to this forum and have been digging around all over...looks like a great community!
I would like to know if there is a way to install Mojave on the following system specs:
Gigabyte GA-Z68X-UD3H-B3
i7 2600k SandyBridge CPU
16GB memory
AMD Radeon HD6870 (GV-R6870C-1GB)
Patriot Torche 240SSD
I attempted to install using the Olarila Mojave image and the Series 5,6,7,8,9 Chipset files, but once I got to the install screen to pick where to install, my drive was greyed out with the message "Mac OS 10.14 cannot be installed on this system", which seems odd as I see lesser system specs running Mojave. Is there any way?
Any help would be appreciated!
u need use a correct smbios, mojave many smbios loose support
u can create ur personal usb stick too
check here
http://dosdude1.com/mojave/
Thanks for the reply MaLd0n!
Unfortunately, it looks like my system will be unusable due to my graphics card, per the listing from the link you provided:
- iMac12,x (systems with AMD Radeon HD 5xxx and 6xxx series GPUs will be almost unusable when running Mojave. More details are located in the Known Issues section below.)
Looks like I'll need to use High Sierra...
if u use iMac13,1, done
press O key in clover boot screen, u see all option there, included smbios
Thanks, I'll give it a try! Very new to hackintosh, so I am trying to get up to speed quickly!
I was able to use the link you provided to get Mojave installed and working on my hackintosh system! Thank you!
However, my blues seem yellow, like I am missing something with the colors on my display. I've played around with Dark vs Light, calibration, etc but to no successful resolution.
Any suggestions?
install SwitchResX and change to million colors
:guitar:cap
