fix sleep hdmi audio i5 4690, Asrock B85m-itx
Hi Guys
I have studied about hackintosh for over a year, experiment on my desktop since Sierra version, since there, I have tried different version from Yosemite all the way to high Sierra and even Mojave, but none of them fully worked, the outstanding issue is related to Sleep and HDMI audio, I cannot remember how long I tried to fix them without any single success, I gave it up so many times, each time, it takes me a few weeks to study from various hackintosh sites. so finnally, I stop here to ask for support from you, hope with your great experience, I will eventually make a perfect hackintosh. here is my issue and the runme apps:
configuration: Core i5 4690 Haswell, mainboard Asrock B85m-itx, Ram 8GB single slot, SSD 240GB OCZ, NVIDIA GT1030.
issue: unable to sleep, each time try to sleep, screen goes off, but the fan still spinning, power light is still on.
no HDMI audio out on NVIDIA card.
I attached hereby the Runme app details for your review
hope your help. thanks
Send me Trans-iMac.zip
[ref]hatran08[/ref], DSDT.aml.zip
Thank you for a very prompt response, I have put your DSDT to patched folder and restarted, but still unable to go sleep. any other thing needs to be done ?
what happens with sleep? ur mobo have a thirty party usb?
upon going to sleep, the screen goes off but the power light still on and fan still spinning,
I patched the USB port before but the issue still existed, so I believe the sleep issue is not of USB port
some asrock mobos, we need disable usb thirt party in bios for sleep work
LEt me check in my bios. Meantime, could you have a look to my attachment to see if there is something wrong that might be potential of sleeping issue? How about the HDMI audio?
pascal dont work hdmi audio with web drivers, u can check applealc site, idk if work, i dont use nvidia more
I have checked, my bios does not have any option of third party USB. so what do I need to do now ?
Added in 28 minutes 6 seconds:
if I don't use web driver how can I make GT1030 recognized by the system ?
[ref]hatran08[/ref], 1030 need web driver
it means, there will be no solution to have hdmi audio on a pascal card like 1030 ? :( okay ignore it
for the issue of sleep, do you have any idea of how to fix it ?
no idea, have all patches in dsdt and config plist, if don't work, idk
Haizzz, thank you anw, I guess, it will not be able to be optimized further
