[HELP] Kernel panic and reboot after install
Hello all,
This is my first hackintosh I have downloaded macOS High Sierra 10.13.6 and created a bootable USB installer using Clover 4674 I used this config.plist https://raw.githubusercontent.com/RehabMan/OS-X-Clover-Laptop-Config/master/config_HD4000_1366x768.plist by RehabMan and changed the clover folder to this https://Olarila.com/files/Clover.Folder/CLOVER.SERIES.CHIPSET.zip by MaLd0n. Installation went OK I booted using USB launched Disk Utility formatted the drive using GUID Partition table started the installation from the terminal it went to 100% and restarted.
After restart when I try to start the OS from SSD using Clover it just reboots so I enabled verbose mode and checked the option to disable restart now the screen text goes to this line
@kec.corecrypto 1.0
and a message to report the panic. I can still boot into the Utilities using the USB.
I am using Samsung NP350 model laptop with Intel® Core™ i5-3210M Processor and Intel® HD Graphics 4000 I really want to get macOS working for this laptop and would appreciate any help... Thanks
post one photo
