AppleHDA Patcher General Discussion
Hi, my codec is CS4213 I tried applealc but it didn't work so mald0n told me to try AppleHDA patcher. but when I run the app and go to the laptop section and there's no CS4213.
Hello guys! Any of you know what to do when the system doesn't load AppleHDA.kext?
I've been reading a lot, looking for a solution but i did't find any..
I'm running Catalina 10.15.4 and I had the same issue with Mojave 10.14.6.
On Jarvis:
No audio codec found!
Be sure to have AppleHDA.kext installed and loaded.
Edited by Seetim
Ryzen 3400G @ 3.7Ghz | 2x8GB DDR4 3000Mhz | Gigabyte B450 Gaming X | Radeon RX 570 4GB | Samsung 750 EVO 250GB | macOS Catalina 10.15.4
Hi, @Mirone! I'm having a strange issue with Catalina and ALC662 here... I've done the patch, installed the Kexts in the Clover folder, did the patches in config.plist and repaired permissions / rebuilt cache. All worked fine! Then I turned off my computer and when I turned it on again, it stoped working. But if I repair permissions / rebuilt cache it works again, it works again. What am I doing wrong? Here's my send me file if it helps: https://filebin.net/s1fifh5vlz7i41v3
Active hack:
  • Intel DB85FL
  • Xeon E3 1220 V3
  • MSI GeForce 710 1GB
  • 8GB DDR3 1333
  • macOS Catalina
GigaByte Z77N-WiFi - High Sierra 10.13.6 (17G14042) - AppleHDAPatcher 1.9
ALC892, only need line out(green) & mic(pink).
I fixed Info.plist, layout36.xml, Platforms.xml and draged into AppleHDAPatcher.
I tried aDummyHDA.kext & Clover but PinConfiguration shown wrong.
I tried use full Patched AppleHDA, PinConfiguration shown right but no sound.
Ofcourse, I repaired permissions and rebuilt caches after installing kext by KextInstallUtility.
Can anybody help?
Tnahks.
IO_Image when used full Patched AppleHDA
codec#2.zip Info.plist.zip layout36.xml.zip Platforms.xml.zip AppleHDA.original.zip
AppleHDA.Patched.Manual.zip
Edited by Chocofate
