AppleHDA Patcher General Discussion
At the beginning of my post I said that I repaired permissions. Using Olarila Repair Permission.app indeed.
use this clover folder: CLOVER.zip
Delete AppleGFXHDA.kext, after repair permissions rebuild caches use Olarila Repair Permissions.app
Added in 4 minutes 36 seconds:
I did the error of updating to mojave, I backup the new applehda and tried to installed the patched applehda you send me but no sound. Can you help?
Files:
Jarvis, Codec_Dump, Send Me files & Terminal Output
Delete AppleGFXHDA.kext, repair permissions rebuild caches.
Files:
Still no sound, Any ideas?
Terminal Saved Output.txt
[ref]bearloverpr[/ref],
try this:files.zip
install two kexts in: S/L/E.
I can see the volume control and also it recognize when I have the internal speakers or the phones but no sound is coming out.
[ref]bearloverpr[/ref], Are you testating with a specific player?
I tried with the system sounds, spotify and you tube, and no sound, the internal mic is working because I can see the level going up when i talk.
[ref]MarsArtis[/ref],
I said codec_dump and not ACPI tables.
Hi Mirone,
maybe I'm doing it wrong, so please correct me.
I'm doing this:
  1. open AppleHDA Patcher.app
  2. show Jarvis
  3. dump
[ref]MarsArtis[/ref], I'm sorry I'm out of the computer at the moment, waiting until I can have some money to buy a new one.
Thanks for this crisp guide.
My laptop details
Dell Latitude E5280
Kabylake i5-7200U, HD 620
Audio Codec ALC225
macOS: 10.14.5
My results wIth AppleALC kext:
I am able to get audio with AppleALC kext and native AppleHDA kext with config.plist layout set to 33. Headphones don't work. They work with ACPIPlugFix, but headphone distortion starts after waking from sleep.
I am interested in using the AppleHDA patch to see if I can do better.
Result with Mirone AppleHDA Patch v1.9:
With fullpatched AppleHDA + DSDT Patches (LayoutID=2, HPET, IRQ) , the speaker icon is greyed out and Sound Output and Input have only USB Audio device if it is plugged inIn config.plist ACPI / HDAS renaming is done to HDEF and Device / Audio Layout = " " (Blank)
I tried everything as per your AppleHDA Patcher v1.9 guide.
All the problem reporting files are attached. Please help me to make the AppleHDA Audio patch work properly with all devices including headphone.
rachanta_problem_report.zip
As I said above, I'm without a computer for hackintosh, at the moment, donations are appreciated to help me with this.
Very useful app! the only problem is I'm losing the subwoofer sound of my laptop, can you please add 2+1 for laptops ?
Realtek alc898 in my case
Hack Pro: Asus Strix Z590i, i9-11900K, RX 6900 XT, 1TB Samsung QVO SSD, RAM 16GB Corsair RGB @3200Mhz (Big Sur) OC
Hackbook Pro: (MSI GE63 Raider RGB) i7-8750H, Intel UHD 630, GTX1070 8GB(disabled), 16GB RAM @2666Mhz (Big Sur) OC
