AppleHDA Patcher General Discussion
[ref]qd121001[/ref],
try this: Files.zip
But first do the following: Open Olarila Repair Permissions.app and click on "Rebuild Caches", reboot, and see if the AppleHDA I sent you earlier will load.
[ref]Mirone[/ref], tried your new Apple ALC, still no sound, :?
your clover fixed my battery percentage issue
[ref]Mirone[/ref], yes, I messaged you team viewer ID, Password
my email :Joey@overseastalent.com.au for chat
Added in 55 minutes 54 seconds:
[ref]Mirone[/ref], there is no audio after reboot,i will try to keep my laptop on all the time, you can try to get access to it.
thank you for help and assistance
i will put APPLEALC back to Kent to test headphone tomorrow
[ref]Mirone[/ref], i tried two latest clover, my laptop constantly reboots unless i choose safe mood.
there is no audio detected in the safemood. I have deleted the VOODOOHDA in kext, it boots normally now.
are you able to have a look at by using teamviewer, I sent you the password. my laptop will be on for next 8 hours
thank you
Hello, its me again, everything seems good now (except the microphone), Jack_fix patch fixed the headphone when connecting, the only problem is the patched AppleHDA gave me Kernel Panic Sometimes, and the mute button is greyed out, the sound not muted when I press mute button. Do you have any solutions or suggestions? Thank You
N.B :
1.ALC 256 Combo codec
301877356_ScreenShot2019-01-14at11_05_24PM.thumb.png.3d7e248603555944b8f1d0f749f11106.png
KPLog.zip
