AppleHDA Patcher General Discussion
Hi, I have ALC256 Audio codec, using Mojave 10.14.1 , my problem is the audio only working with AppleHDA Patcher build 1.8, the one that (Still) using layout-id=3, but the microphone doesn't work (I don't know why), could you analyse the problem as the AppleHDA that patched by myself also didn't work, and I'm using AppleHDA.kext form High Sierra 10.13.6, using patched AppleHDA kext from Mojave didn't work (for now).
Send me Riskys-MacBook-Pro.zip
CodecDump.zip
1504565938_ScreenShot2019-01-06at17_12_25.thumb.png.a9ff5d5b731a1576a52fee08875536b4.png
Please Help, ALC 294
Install AppleHDA in /S/L/E, use Olarila Repair Permissions for this, then copy the Jack_Fix folder to your Desktop and double-click install.command.
Use Layout-ID=3
Added in 33 minutes :
This codec has no microphone in its codec dump, it's a known problem but no solution so far, at least I have not found a solution.
ALC294.zip
Okay thanks, this solved my curiosity, but i think i found the problem. The microphone is built in with another device from Intel Audio...
Thank you for replying
[ref]Mirone[/ref], thank you, tried, still no luck,
i deleted original APPLEHDA,InstallED AppleHDA in /S/L/E, BY using Olarila Repair Permissions,runed Jackfix.
it still cannot detect any sound devices
IMG_20190110_105814_BURST001_COVER_resized_20190110_110122089.thumb.jpg.1a88a698a1c0d7671fcf6f5c4d06899e.jpg
IMG_20190110_105848_resized_20190110_110147827.thumb.jpg.1ff327c1c8d2da0c63e013bcc699f6a1.jpg
IMG_20190110_105926_resized_20190110_110210014.thumb.jpg.c921e83607386e501e53f40bddb9d053.jpg
still no audio device
Use RunMe.app and send me the files generated by it.
Added in 4 minutes 50 seconds:
need help, I'v been working on my audio, but still no sound. Any suggestion?
here my codec from live ubuntu
There are many factors that can influence so that the audio does not work properly, in addition to that there are many variants for ALC269, my suggestion is that you test them all.
please help if there is any other solutions
Later today I will send you some files, including a new folder CLOVER its very messy.
