Mirone Posted December 8, 2018 Author Posted December 8, 2018 but aDummyHDA does not get loaded after booting when using Clover method Did you repair the permissions and rebuild the caches?
dekifx Posted December 9, 2018 Posted December 9, 2018 [ref]Mirone[/ref], already did everything but doesn't work, i use layout id 2 and 13
Mirone Posted December 9, 2018 Author Posted December 9, 2018 AppleHDA Patcher use only layout-id=2 for laptops, send-me your codec_dump i analyze for you ASAP.
dekifx Posted December 9, 2018 Posted December 9, 2018 Here[ref]Mirone[/ref], i hope it will work with the internal mic also bcs using AppleALC the mic won't work codec_dump.txt
Mirone Posted December 10, 2018 Author Posted December 10, 2018 How is it sir? I have a life beyond the Hackintosh scene, be patient.
Mirone Posted December 10, 2018 Author Posted December 10, 2018 [ref]dekifx[/ref], Try this:Files.zip Install AppleHDA in; S/L/E, repair permissions rebuild caches. replace your clover folder with it attached.
dekifx Posted December 10, 2018 Posted December 10, 2018 [ref]Mirone[/ref], i'm sorry for bothering you sir, Thank you so much for the patch im going to test it soon Added in 52 minutes 12 seconds: [ref]Mirone[/ref], Still not working sir, no audio devices detected
Mirone Posted December 10, 2018 Author Posted December 10, 2018 [ref]dekifx[/ref], try this: AppleHDA-282.10-ALC256_v2.zip AppleHDA-282.10-ALC256_v3.zip
dekifx Posted December 11, 2018 Posted December 11, 2018 [ref]Mirone[/ref], Thank you so muchh! My audio is working flawlessly now!??
Mirone Posted December 11, 2018 Author Posted December 11, 2018 [ref]dekifx[/ref], Which version of kext?
dekifx Posted December 12, 2018 Posted December 12, 2018 [ref]Mirone[/ref], The v2 works good for me but didn't tested the v3 yet
dekifx Posted December 16, 2018 Posted December 16, 2018 [ref]Mirone[/ref], I have a strange problem sir, when I boot into windows and then restarted to macOS the audio devices is detected but no sound, how to fix that sir? Thanks in advance
onemanosx Posted December 16, 2018 Posted December 16, 2018 Everyone should always attach send_me files when reporting problem. Run this app http://Olarila.com/files/Utils/RunMe.app.zip [ref]dekifx[/ref], Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
dekifx Posted December 18, 2018 Posted December 18, 2018 [ref]onemanosx[/ref], here is my RunMe output sir, The problem is when i boot to windows and restarted to macOS the audio won't output a sound but the audio devices is detected, and i must shutdown it first and boot again after booting into windows if i want to make the audio to work in mac. Send me Dekis-MacBook-Pro.zip
Mirone Posted December 18, 2018 Author Posted December 18, 2018 This is not a problem with AppleHDA Patcher and yes its config.plist, sorry guys but off topic will no longer be accepted here.
preben Posted December 23, 2018 Posted December 23, 2018 I have a Soundblaster Z (CA0132). I have tried AppleALC and all ids without success. Do you have any suggestions? I attach a screenshot where there is a comparison between audiocodecs.txt(runme.app) and DPCImanager. If you need something other just ask me.
preben Posted December 23, 2018 Posted December 23, 2018 Here you are send_me files. Send me Mac-mini-of preben.zip
Mirone Posted December 26, 2018 Author Posted December 26, 2018 I have a Soundblaster Z (CA0132). I have tried AppleALC and all ids without success. Do you have any suggestions? No Idea, AppleHDA Patcher does not support this codec, problems with AppleALC should be handled with its Developers.
preben Posted December 27, 2018 Posted December 27, 2018 No Idea, AppleHDA Patcher does not support this codec, problems with AppleALC should be handled with its Developers. Ok. I'll search somewhere.
