karwan Posted August 18, 2018 Posted August 18, 2018 (edited) I HADE PATCH THE SSDT AND DSDT AND SCROE EVERYTHING AND I HADE FORCE TO REMOVE ALL MY WORKS ANY SUGGEST THE RIGHT WAY TO PATCH THOSE ON MY DELL LA E6220 THE RIGHT WAY ANY ONE HAD !? THANKS TO ANY HELP macOS High Sierra 10.13.6 DELL Latitude E6220 PROCESSOR: 2.49 GHz INTEL COR i5 GRAPHICS: INTEL HD3000 512 VRAM RAM 8 GB DDR3 1333MGz Edited August 18, 2018 by Guest
Administrators MaLd0n Posted August 18, 2018 Administrators Posted August 18, 2018 run our app and post dump here RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
karwan Posted August 18, 2018 Author Posted August 18, 2018 sorry for delay in process. EDIT: https://imgur.com/a/7FnRWiq this is happen with me every 5 sec siri popups
Administrators MaLd0n Posted August 18, 2018 Administrators Posted August 18, 2018 ye, disable siri and run it, dont touch in nothing, just wait finish -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
karwan Posted August 18, 2018 Author Posted August 18, 2018 in process agin I hope got success EDIT: same thing I got this folder in tem if this is help!? send_me.zip
Administrators MaLd0n Posted August 19, 2018 Administrators Posted August 19, 2018 DSDT.aml.zip generate one ssdt for PM https://Olarila.com/files/Utils/SSDT_Automator.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
karwan Posted August 19, 2018 Author Posted August 19, 2018 thank you so much I had do it but does this is mean anything ? I was have some problems I hoped got resolve theme with patch ssdt like>> system freezing must hard reset on power button Framebuffer Depth: 24-Bit Color (ARGB8888). I have 24 instead of 30-Bit and glitchy line on my videos appears does this mean I need some kind a better graphics or it's problem with my lap is old?
Administrators MaLd0n Posted August 19, 2018 Administrators Posted August 19, 2018 HD3000 in new system have a some bug in many cases el capo or sierra work good -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
karwan Posted August 19, 2018 Author Posted August 19, 2018 aha yep it's right many many bugs really thank t=you again I will switch to elcapo I have already installed! thanx again for your time appreciate
