strange sleep problem with ga-p67a-ud4-b3 f5
Hello Guys,
got a strange Problem with my Hack. When I send him to sleep or he went to sleep and i wake him i got no video output.
hack is in proper sleep no fan spinning etc. replugging also don't help. i tried the rtc patch, adding the darkwake=0 flag and it not helped.
also tried with unplugging the dvd drive. only using the intel sata ports and no raid mode
i'm now on chameleon before i was on chimera also reinstalled several times the system ...
somebody got an idea? if someone could help it would be great :roll:
here my system
Ga-p67a-ud4-b3 f5
i5 2500k
2x 4 gb team group ddr3 1333 mhz
geforce gtx 460 sparkel
dsdt from tony
kext installed
Alc8xxhda.kext
applehda.kext
fakesmc with plugins
realtek driver
AHCI_3rdParty_eSATA.kext
IOAHCIBlockStorageInjector.kext
fixes i use
netkas open cl fix
rtc cmos rest fix
kernel flags
npci=0x2000
darkwake=0
speed steeping
i try to cook my dsdt with dsdt-editor patch for ga-p67a-ud4-b3, ahci icon fix and alc889 but got no audio and sleep problem still there ...
i add the patch for audio like the other one's did i something wrong? tried also 889a
Are you using the AppleRTC patch to avoid CMOS reset after sleep/restart?
http://www.insanelymac.com/forum/index.php?s=&showtopic=253992
Try to enable/disable "repost video on S3 resume" in BIOS.
