ramzi Posted August 30, 2018 Author Posted August 30, 2018 okay. no problem) thank you again Mirone everything is okay. i solved my problems. i am very grateful to you for your help. will my sound work in mojave with this applehda? or i will patch applehda again?
Mirone Posted August 30, 2018 Posted August 30, 2018 okay. no problem) Try this:AppleHDA-v4.zip Let me know if your external microphone works, use an iphone headset or similar.
ramzi Posted August 30, 2018 Author Posted August 30, 2018 headphones, microphone and internal work fine. You asking me about headphones's microphone?
Mirone Posted August 30, 2018 Posted August 30, 2018 You asking me about headphones's microphone? yes.
ramzi Posted August 30, 2018 Author Posted August 30, 2018 this file v5 also not working. for me internal microphone"s working enough. thank you again Mirone) will my sound work in mojave with this applehda? or i will patch applehda again?
Mirone Posted August 30, 2018 Posted August 30, 2018 Quote will my sound work in mojave with this applehda? or i will patch applehda again? for Mojave follow these steps: https://olarila.com/topic/20908-easy-fast-and-perfect-vanilla-hackintosh/
Mirone Posted August 31, 2018 Posted August 31, 2018 Appreciate if you can post your dsdt file for our analysis. Thanks. try this:AppleHDA_ALC255_v1.zip Use Layout_id=2 in your DSDT or config.plist
ramzi Posted November 17, 2018 Author Posted November 17, 2018 hello. can someone help me with the updating applehda to Mojave?
ramzi Posted November 17, 2018 Author Posted November 17, 2018 I tried to do that, but I dint understand the third step "script de bcc9". Explain me/please
nadeem_khan7 Posted February 20, 2019 Posted February 20, 2019 even im having the same issue on my asus x541uvk☹️
juanvascas Posted March 12, 2019 Posted March 12, 2019 I have a dell G7 and my microphone is not working (internal mic) may the AppleHDA v3 fix kext from Mirone work for me? I see both laptops have the alc256
