Asus x541ua touchpad voodooi2c elan1200 problem
Hello everyone. My notebook model is Asus x541ua and I successfully installed high Sierra system. And everything work except touchpad. Controller is HID i2c. I have tried rehubman guide voodooi2c, but when I patched dsdt appears errors with parseop zero, and I don't know how can I delete this errors. Please help me(((if you want i can send you my dsdt
If you have windows, can you let me know the ACPI ID of your device like in the photo?
Donate
Gitter Chat
MSI B360 Gaming Arctic
1. Use config.plist attached. I added a patch to disable apple's controller config.plist.zip
2. Rebuild kext cache and permission using kext utility or similar and reboot.
If still not working try this DSDT. DSDT.aml.zip
You might need VoodooI2CElan.kext also. Try and see if it works.
Donate
Gitter Chat
Perhaps Alexandre could help. Go to his github chat.
Can you check if the kext is loading? see ioreg
Sorry, I am not of any help.
Donate
Gitter Chat
I got a little bit of time and had another go to see if this DSDT will solve it for you.
1. DSDT.aml.zip
2. Use this config.plist with kext patch https://Olarila.com/forum/download/file.php?id=10562
3. Install kexts in clover>kexts>others
a. VoodooI2CHID.kext (or add VoodooI2CElan.kext if doesnt work)
b. VoodooI2C.kext
Donate
Gitter Chat
