After install "AppleHDA and Codeccommander" to Library>Extension..audio work but it looks different on hardware information...
manufacture is unknown...
2.After update High Sierra 10.13.5 to 1.10.6 bluetooth not working...
use BT kexts in L/E or S/L/E
How I find this kext..
02:00.0 Network controller [0280]: Intel Corporation Wireless 3160 [8086:08b3] (rev 83)
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [10ec:8136] (rev 07)
If your audio is working, do not worry about it.
ok..
And bluetooth issue....After update High Sierra 10.13.5 to 1.10.6 bluetooth not working
is a intel, the best is disable it
Yes Working,but not 100%.
Problem is:when I try to record audio with internal mic it makes crackling and disgusting sound in headphone output, I can't listen anything.
and sometimes automatically makes crackling and disgusting sound in headphone output. after reboot audio start working.
