Help with Legion Y520-15IKBN sleep, graphics and wifi
Hi,
I got my hackintosh 10.13.5 working. But after boot even if i change anything in config.plist using clover editor and rebooting ,nothing seems to take effect.
System config is:
Intel Core i5-7300HQ Processor ( 2.50GHz 2400MHz 6MB )
8.0GB PC4-19200 DDR4 SODIMM 2400MHz
NVIDIA GeForce GTX1050 4GB GDDR5
Qualcomm Atheros QCA6174A
As of now my system is showing only intel HD630 integrated graphics, is there a way to enable gtx1050?
I tried setting inject nvidia, nvdrv= 1 etc but these settings seems like getting ignored.
Also i observed battery life is half when compared to windows 10. In intel power app everything seems to be normal.
Is there a way to fix sleep?
Attached my runme files
Send me zfxs-MacBook-Pro.zip
is a optimus, if yes, u need disable nvidia and use only intelhd
yes,optimus. So i need to send nv_disable in boot options?
Also is the above wifi supported?
Can you help me with sleep and power management
press barspace and block Lilu
use ever last clover version
use ur clover folder and put my DSDT in Clover/Acpi/Patched
same kp?
try
use a full clover folder
CLOVER.zip
got panic again.
1339759210_ScreenShot2018-07-29at10_45_23PM.thumb.png.3c46c230a857766aff9c31db460f41ab.png
With my current conig pc is going to sleep for a brief moment and keyboard lights and fans are turning on again. After wakeup pc functions very slow until restart.
the problem is Power Management
use ur old clover folder, u need test what cause KP, looks like a Lilu or Whatevergreen kext
directly
