Help on High Sierra 10.13.6
stefjefry
Hi!
After reading a lot of guides I'm trying to get a working mackintosh 10.13.6 on my Dell 3542.
Laptops specs are :
Intel 4005u , 17ghz
8gb ram
Intel HD 4400
Broadcom BCM94352HMB
I want to help to get a  working dsdt, ssdt, clover, config.plist etc. Also , I would like my network card to be recognised at boot-clean installing and have airdop/handoff enabled.
Please , help me out to get the best possible hackintosh for my laptop
Thanks in advance.
Here is my dump files :https://mega.nz/#!6dICiSbB!OB9fKoXE9oO2PSbU7rHHReNNrQVRaUDNoPdg8-8REmI
Link to comment
Share on other sites
yes, generate one ssdt
I generated a ssdt.aml and a ssdt.dsl file. Do I just copy then to clover/acpi/patched folder ?
Do I have to add an entry to congig.plist ?
Does this seem right for my laptop (Intel i3-4005u 1.7ghz , Intel HD 4400) ?
CPU Ratio Info:
Base Clock Frequency (BLCK)............. : 100 MHz
Maximum Efficiency Ratio/Frequency.......: 8 ( 800 MHz)
Maximum non-Turbo Ratio/Frequency........: 17 (1700 MHz)
Maximum Turbo Ratio/Frequency............: 17 (1700 MHz)
IGPU Info:
IGPU Current Frequency...................: 750 MHz
IGPU Minimum Frequency...................: 200 MHz
IGPU Maximum Non-Turbo Frequency.........: 200 MHz
IGPU Maximum Turbo Frequency.............: 950 MHz
IGPU Maximum limit.......................: No Limit
P-State ratio * 100 = Frequency in MHz
CPU P-States [ (8) 17 ] iGPU P-States [ (15) ]
CPU C3-Cores [ 0 1 2 3 ]
CPU C6-Cores [ 0 1 2 3 ]
CPU C7-Cores [ 0 1 2 3 ]
CPU P-States [ 8 16 (17) ] iGPU P-States [ (15) ]
CPU P-States [ 8 16 (17) ] iGPU P-States [ 15 (19) ]
CPU P-States [ 8 16 (17) ] iGPU P-States [ 15 (16) 19 ]
CPU P-States [ (8) 15 16 17 ] iGPU P-States [ 15 16 (19) ]
CPU P-States [ 8 15 16 (17) ] iGPU P-States [ 15 16 (18) 19 ]
CPU P-States [ 8 15 16 (17) ] iGPU P-States [ 15 16 (17) 18 19 ]
Link to comment
copy to clover/acpi/patched, ssdt.aml
Link to comment
looks good, take a tests, use for some days and check if work good
Link to comment
Biggest problems till now are :
1) close lid doesn't enable sleep
2) There is no brightness slide in properties/display.
BRIGHTNESS.zip
with lid close pc don't sleep or don't wake with open?
Link to comment
When closing lid pc don't sleep.
Sleep works ok if I select sleep for menu.
u need try solve it with fix edid, check in google search, it's a common problem
Link to comment
Strange thing ...
Brightness patch you sent me fixed lod close sleep and wake !!! But still no brightness slider.
It says that applebaclightinjector.kext is not loaded (photo in Greek , οχι means no , χωρις υπογραφη means no signature)
Link to comment
put applebaclightinjector.kext in library/extensions and run KextUtility
Link to comment
