Konclaw Posted July 24, 2018 Posted July 24, 2018 Good morning, someone could help me with my laptop, it is a dell 7567 which has an i5 7300 HQ processor, an integrated Intel HD 630 graphics and an ACL265 audio codec to which HS 10.13.1 installs, almost all devices they are working excellently, it was necessary to replace the network interface with the DW1560. But unfortunately there are things that I can not solve and I would like to know if someone can help me. 1) The first problem is the subwoofer that has the laptop, I can not make it work, so the audio is not heard very well. 2) the bluetooth has a problem, when disconnecting a device it stops working properly, you can not deactivate or look for other devices, for which you have to restart. I attach my results of "RunMe.app". Send me Martins-MacBook-Pro.zip
Allan Posted July 24, 2018 Posted July 24, 2018 1) The first problem is the subwoofer that has the laptop, I can not make it work, so the audio is not heard very well. Some users have the same problem as you. You can try using a patched AppleHDA, look at this app. AppleHDA Patcher v1.9 2) the bluetooth has a problem, when disconnecting a device it stops working properly, you can not deactivate or look for other devices, for which you have to restart Try this: Bluetooth Firmware Uploader Thanks & Regards IdeaPad Gaming 3i • Aspire A515-52 • Clover / OpenCoreWe are in a great Forum, so, let's have some fun and learn from each other!
Konclaw Posted July 25, 2018 Author Posted July 25, 2018 Try this: Bluetooth Firmware Uploader Hello, thank you very much, I already managed to fix the problem of the bluetooth, but I still have the problem of the audio, try to use your solution but I do not understand much that there is to do.
Michelle Perry Posted February 23 Posted February 23 (edited) On 7/24/2018 at 9:03 PM, Konclaw said: Good morning, someone could help me with my laptop, it is a dell 7567 which has an i5 7300 HQ processor, an integrated Intel HD 630 graphics and an ACL265 audio codec to which HS 10.13.1 installs, almost all devices they are working excellently, it was necessary to replace the network interface with the DW1560. But unfortunately there are things that I can not solve and I would like to know if someone can help me. 1) The first problem is the subwoofer that has the laptop, I can not make it work, so the audio is not heard very well. 2) the bluetooth has a problem, when disconnecting a device it stops working properly, you can not deactivate or look for other devices, for which you have to restart. Good morning, já passei por situações parecidas tentando resolver problemas técnicos no portátil e sei como pode ser frustrante quando algo quase funciona mas não totalmente. Depois de horas mexendo em drivers e configurações, às vezes preciso dar uma pausa para não perder a cabeça. Num desses intervalos acabei encontrando VBet e vi que oferece bônus especiais para jogadores do Brasil. Comecei no Fortune Tiger só para distrair, tive várias rodadas seguidas de perdas e pensei em fechar, mas arrisquei um pouco mais e consegui um prêmio grande que mudou o clima do dia. Desde então uso com moderação quando preciso desligar um pouco da parte técnica . I attach my results of "RunMe.app". Send me Martins-MacBook-Pro.zip 2.74 MB · 19 downloads Morning! i have the same situation( Edited February 23 by Michelle Perry
