Help me, 10.14 nvme patch
mosun1
我的nvme ssd是LENSE10512GMSP34MEAT2MA(Marvell88SS1093-BTB2+TH58TFT1JFLBAEG*2).
nvme patch:
IONVMeFamily
f6c1100f8541010000
f6c1010f8541010000
IONVMeFamily Patch
10.13.x
10.13.6 can be used normally, but the installation of 10.14, nvme patch is invalid, can not find this nvme. 10.14 is not nvme patch address has changed?
Link to comment
Share on other sites
i think change it too, apple change all, need check if ppl create patch for 10.14
Link to comment
buy ever samsung 960, is a full native support
Enjoy
Link to comment
Where I can find the ionvmefamily? I'm using Mojave in Acer F5-573G with Samsung EVO 960.
ur nvme don't need any patch, is native
Link to comment
OK, the problem is solved, and the 10.14 beta is successfully installed.
how do you solve it ? the pciture is lost., my nvme is LENSE20256GMSP34MEAT2MA. lenovo carbon x1 cg6.
Added in 1 minute 36 seconds:
the picture is lost .can you tell me how you solve it? LENSE20256GMSP34MEAT2MA is my nvme. lenovo x1 cg6
Link to comment
[ref]zhiyuanliu[/ref], ur model i think don't work, check in google if u see infos about it
Link to comment
hello my nvme m.2 ssd have very slow read / write speed. I couldn't find the problem.
Corsair Nvme M.2 MP500 120Gb
SD Max Sequential Read ATTO Up to 3000MB/s
SSD Max Sequential Write ATTO Up to 2400MB/s
SSD Max Sequential Read CDM Up to 2300MB/s
SSD Max Sequential Write CDM Up to 1400MB/s
Link to comment
[ref]çiçero[/ref], very bad, i have no idea, this ssd have a native support
Link to comment
