ESP Mounter Pro is a new top bar application to manage your EFI System Partition(s). You can mount or umount any ESP you have on any disk you have directly from its popover window.
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
This app use advanced APIs to perform all operations and no AppleScript or scripts are used: only code!
Require 10.9 +
Download ESP Mounter Pro v1.9.1 ESP Mounter Pro.zip
 Created by Micky1979 on 15/06/16.
Copyright © 2016 Micky1979 All rights reserved.
app icon by Mirone (thanks)
Does not show an EFI Partition if your disk is not GPT (or if smaller than 1GB). Cannot mount it if corrupted!.
Thank you Micky1979 for keeping up his great work!
We're all here to have fun and learn from each other! That's all Folks!
  • Like 2
Very Nice! Thanks for update, guys!!!
About This File:
Require 10.9 +, works good in Mojave Beta!!
// Created by Micky1979 on 15/06/16.
// Copyright © 2016 Micky1979 All rights reserved.
Download Here
amazing, thanks for creator.
Thanks for update :D
Gigabyte Z390 Aorus Master (BIOS F11h) - i7 9700K - 16Go RAM 3000Mhz Corsair - MSI Radeon RX580 Armor - IIyama Prolite XB2783HSU 27" - Fenvi FV-T919
HHD1: Clover - MacOS Catalina 10.15.5  - HDD2: Windows 10 Pro November 2019 Update External: macOS Big Sur 10.16 Beta
Thanks Mirone
And a thank you to Micky1979
Placa-mãe: Gigabyte GA-Z77P-D3 (rev1.1, Bios F8e)
Processador Intel: Core i5 3470
Placa de vídeo Gigabyte: Radeon HD7850
Memória kingston 16G DDR3
Wi-Fi/BT4.0 Broadcom: BCM94360CD
Rede Realtek: RTL8111E-VL/8168E-VL
Codec Áudio Realtek: ALC887
Hi!
First off I would like to thank you for the amazing useful tool!
However, I am having a small issue with it not able to open the mounted partition. See attached video example. I have 2 drives both in GPT. While my hdd is able to mount and open folder, my ssd (No Name) can only be mounted but not opened through the app.
Do you think I can manage this by just renaming "No Name" to "EFI"?
Thank you!
Donate
Gitter Chat
MSI B360 Gaming Arctic
Strange. I am using HFS+tho..
Donate
Gitter Chat
Nope ESP Mount Pro doesn't rely on the name.
Thanks for the video, so I think I solved the problem, try attached. Be aware that a new helper tool will be installed and the first time will require the app to be manually restarted. Let me know.
[hideurl=https://mega.nz/#!QyR1AK6Y!VqM8NCUC6T7a9btPDtJ5l_KG6SSFHli5Nq6_BP8xLLQ]ESP Mounter Pro_v1.9.1.zip[/hideurl]
EDIT
App repacked with a new certificate. This one will be valid for the next 10 years. :D
Yes! This works! Glad the video helps! Thank you!!
Donate
Gitter Chat
Beautiful work @Mirone & @Micky1979!
Just a note, I set up one of my monitors for HiDPI and it makes the app's icon distort in the menu bar. I've attached a picture. Any fixes for that?
1865850055_ScreenShot2018-08-13at8_12_51PM.thumb.png.0e3cb8d869c8a66e7e8673dab0e6d034.png
