Hello..
Today, i need help for fixing realtek ALC269. After i install Elcapitan till now it is not any problem with my sound, but when i to try connecting to external speaker or headphone. it turn out my sound did'nt work perfectly. My speakers or headphones do not sound, but the sound keeps on my laptop.
I have a teamviewer for make easy for investigated the problem, because i don't know how to patch AppleHDA T_T
Thanks for helping...
and i have tried use 0x100004, 0x100100, 0x100202, 0x100203 layout 1-10, 11, 13, 14, 15, 16, 18, 19, 20, 27, 28, 29, 32, 33, 35, 40, 76, 93, 99, 127 but nothing work perfectly.
try layout: 2-3-4-5-6, if not working I need your codec_dump.
I have to tested using 2,3,4,5 and 6 and it still same condition. how to i dump my audio codec?
use a distro linux of your preference(Live Cd) open terminal run this:
cd ~/Desktop && mkdir CodecDump && for c in /proc/asound/card*/codec#*; do f="${c/\/*card/card}"; cat "$c" >
CodecDump/${f//\//-}.txt; done && zip -r CodecDump.zip CodecDump
send me the files.
try this:
AppleHDA-274.12-ALC269VB_v1.zip
I am sorry late for give feedback, I have to try it and the problem is not fix...
First,
I added AppleHDA.kext using kext utility, and then add patch DSDT like this...
Then, set clover plist like this...
But my sound didn't work like it...
This current DSDT patched...
DSDT-patched.zip
Thanks mirone...
Remove AppleALC.kext and use this DSDT:
After I remove AppleALC.kext and using this DSDT, Because my laptop only have 1 port sound jack, the sound after patched only work for line-in sound like this.
Before i plug in my headphone/headset :
After i plug in in my headphone/headset :
But on my output device didn't work, after i plug in my headphone/headset my sound keep ringing on my internal laptop speaker.
Here i include generate from "RunMe.app" => http://www.mediafire.com/file/iie9hlxeiefysfv/Send%20me%20192.168.0.101.zip
try this:
AppleHDA-274.12-ALC269VB_v2.zip
Forgive me for late giving feedback Mirone, this work very well and perfectly like it...
Audio Output:
Audio Input :
Thank you very much Mirone..
