Hi everyone I manage to install 10.12.6 on my HP Pavilion 15-n220se notebook almost everything works fine
Specification :
Processor: Intel Core i7-4500U (1.8 GHz, 4 MB cache, 2 cores)
RAM: 8GB PC12800 DDR3L (Use 1 Slot)
HDD: 250Toshiba
VGA : Intel HD Graphics 4400 + NVIDIA GeForce GT 740M (2 GB DDR3 dedicated)
Display: 15.6" Internal Display LED
What's working
1. Shutdown, Restart and Good Sleep
2. Close LID for Sleep and Open LID for Wake
3. Working Ethernet
4. Working iMessage (I used "ROM" and "MLB" of Real Mac )
5. Sound via VoodooHDA.kext Patching (All Working, Input dan output)
6. USB 3.0 and all of USB Port
7. Webcam Camera
4 - Card Reader http://www.mediafire.com/file/80nqxg7jz4cfvyp/Sinetek-rtsx.kext-0.1-btest.zip/file
8. wifi, not Compatibility I'm using Ralink 5370 USB Patching WIFI Network macOS High Sierra http://www.mediafire.com/file/919p98vsv65hxi4/Wifi_Atheros_AR9485_V16.zip/file
Fixed:
Battery work using ur DSDT and RehabMan Battery-Driver file number 2014-0207 " thnx to by artur-pt "
Brightens fixed by using brightness-slider https://itunes.apple.com/tn/app/brightness-slider/id456624497?mt=12
But still need to be fixed
Not working:
HDMI I get a black screen
Hi thanks for ur help .. sorry I took too long to reply busy at work :roll:
I did manage to make battery work using ur DSDT and RehabMan Battery-Driver file number 2014-0207 8-)
And for brightness didn’t work the slide show up but didn’t change the brightness
