Ok mald0n .. i wanna try to install this.. thank so much for help me.
welcome
enjoy
Hello, Mald0n...
After I download Sierra Olarila 10.2.6 and I success install them. please help me again to fix and patch my dsdt config, because I don't understand ho to fix them T_T...
DSDT is a principal bios/uefi table, u don't need patched again, only if need change ;)
Thanks Mald0n,
After i wanna try sierra, my laptop feels very slowly.. then i decide to revert back to El-Capitan again ^_^...
But, i found this some problem about my audio and usb.
1. Audio
When i wanna connected external speaker using line-out, that cannot connected perfectly. my external speaker does not work.
2. USB
When i wanna connected my usb flashdisk, that appear error "USB needs Power" look like that
This my debug system => http://www.mediafire.com/file/iie9hlxeiefysfv/Send%20me%20192.168.0.101.zip
check if usb work good
CLOVER.zip
audio, u just need a correct layout-id for ur codec
Thanks, i wanna to try... ^_^
How to change and detect my layout-id for my codec? is setting on config.plist or on dsdt?
if have _dsm into device hdef in dsdt, u need edit dsdt o remove _dsm and inject via clover
Ok Mald0n, is the step like this?
1. Remove Method _DSM in HDEF
2. Inject via Clover Here
3. Using Layout ID Here
Forgive me Mald0n If I ask a lot, because I'm still a beginner and starting to learn hackintosh especially dsdt T_T...
correct, remove _DSM and inject via Clover
use it in MacIasl for easy remove _dsm into HDEF
into method label _DSM parent_adr 0x001B0000 remove_entry;
Thanks Mad0n... we will to try this :-)...
Helo mald0n, can you help me again for correcting my dsdt and other config? this problem about shutdown / restart. According to the first topic, my laptop can't completly shutdown. But using current config shutdown still not fix, but when i to try restart button, my laptop suddenly shutdown ^_^, we very happy because my laptop can shutdown now. but it's not perfectly :)
Can you helpme to fix my restart & shutdown?
Runme File
Thanks Mald0n ^_^
u install RC Scripts in Clover?
How to check it mald0n?
check all
:lol:
is a mistery
