Helo brothers,
I have a problem shutdown with my hackintosh, currently I am using El-Capitan 10.11.3.
The problem is when I click the shutdown button, the screen off but the machine and fan are still on.
and this is the spec of my laptop:
- Asus K42JC
- Intel i5 M460 @2.53GHz
- Ram 8GB
- Intel HD 1st Generation
- HDD 500GB
And the dsdt file i include on attachment file.
Please help me to fix this...
Thanks, for your attention and help.
DSDT.zip
Thanks a lot maldon,
is this dsdt included all to apci / patch? or just select one that works?
have all essentials patches
test one by one
drop all OEM tables
After I try, shutdown still not work. and this is my config.plist
config.plist.zip
POST A FULL DUMP
RunMe.app
This "Post full dump"
i'm sorry using external url because cannot upload to attachment, the file is to large.
http://www.mediafire.com/file/iie9hlxeiefysfv/Send%20me%20192.168.0.101.zip
USE FULL CLOVER FOLDER
CLOVER.zip
I have replaced and added to the clover folder, but shutdown still not completely. Correct me if i am wrong, this my clover folder after i add them.
http://www.mediafire.com/file/84bm8lmn04oemhx/CLOVER.zip
Hello Maldon, is the files I send is enough?...
shutdown don't work?
try a simple patch
I've tried using this way but shutdown problem still not resolved, the screen is off but the engine and fan are still on.
Here I include the system information using your dsdt.
http://www.mediafire.com/file/4xd7u5w6a ... ok-Pro.zip
i don't have idea, all patches is done, if don1t work...idk
Thank you very much maldon, what is the best macos version for my laptop spec above? is support upgrade to sierra or high sierra?
go to sierra, is a good system ;)
