Daemon Posted May 22, 2018 Posted May 22, 2018 Hi, I am having some problems with my Clover boot loader and i heard that this forum is very helpful from a friend. The problem is that i would like to have Clover as my main boot priority so when i boot i get the option to boot into MacOS High Sierra or Windows 10. At the moment i need to use F8 on boot to select my boot drive and then search through the boot options to find "Boot MacOS from High Sierra". I have had numerous problems with my sound also and it is not working on MacOS. I am looking for some help because i would like to have all of the junk partions hidden in Clover (Apart from MacOS and Windows boot partitions), At the same time i would also like my sound to work in MacOS High Sierra. Any help is appreciated, Feel free to ask any questions about this thread. Thanks. ASUS ROG Maximus XU Hero (WiFi) - Socket 1151 | Z390 Chipset | LAN Intel i219-V | WiFi/Bluetooth Intel Wireless-AC 9560 | Audio SupremeFX S1220 | USB Z390 Chipset | Intel i7 9700k Corsair Vengeance RGB PRO DDR4 3600 (2x8GB) RTX 2070 4GB Samsung SSD 500GB
Administrators MaLd0n Posted May 22, 2018 Administrators Posted May 22, 2018 post ur files here http://Olarila.com/files/Utils/RunMe.app.zip dual boot in 2 hds or same hd? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Daemon Posted May 22, 2018 Author Posted May 22, 2018 Send me 877devs-Mac-Pro.zip Thanks, on two separate drives. Windows 10 is legacy. You already did a DSDT.aml on the insanely mac forums a long time ago which is in the patched folder ASUS ROG Maximus XU Hero (WiFi) - Socket 1151 | Z390 Chipset | LAN Intel i219-V | WiFi/Bluetooth Intel Wireless-AC 9560 | Audio SupremeFX S1220 | USB Z390 Chipset | Intel i7 9700k Corsair Vengeance RGB PRO DDR4 3600 (2x8GB) RTX 2070 4GB Samsung SSD 500GB
Administrators MaLd0n Posted May 22, 2018 Administrators Posted May 22, 2018 You already did a DSDT.aml on the insanely mac forums a long time ago which is in the patched folder system reserved partition don't appears in clover boot screen? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Daemon Posted May 22, 2018 Author Posted May 22, 2018 "Windows System Reserved" partition shows up in Clover. ASUS ROG Maximus XU Hero (WiFi) - Socket 1151 | Z390 Chipset | LAN Intel i219-V | WiFi/Bluetooth Intel Wireless-AC 9560 | Audio SupremeFX S1220 | USB Z390 Chipset | Intel i7 9700k Corsair Vengeance RGB PRO DDR4 3600 (2x8GB) RTX 2070 4GB Samsung SSD 500GB
Administrators MaLd0n Posted May 22, 2018 Administrators Posted May 22, 2018 legacy, use system reserved for boot uefi, use EFI entry for boot -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Daemon Posted May 22, 2018 Author Posted May 22, 2018 Thanks, The system reserved boots to Windows 10, I am now going to attempt to hide the other partitions. All worked thanks for your help. ASUS ROG Maximus XU Hero (WiFi) - Socket 1151 | Z390 Chipset | LAN Intel i219-V | WiFi/Bluetooth Intel Wireless-AC 9560 | Audio SupremeFX S1220 | USB Z390 Chipset | Intel i7 9700k Corsair Vengeance RGB PRO DDR4 3600 (2x8GB) RTX 2070 4GB Samsung SSD 500GB
