Hackintosh Guide - High Sierra / Mojave / Catalina / BigSur / Monterey on X299 with Clover Bootloader
4 hours ago, MaLd0n said:
u need use a supported smbios
I install already. But i have a problem.
when intry to unmount my hdd to check / edit the config. I can’t see any clover inside on efi main hdd.
edit:
i cant boot normal, always ready to boot on preboot. How to fix this sir?
Edited by GOVERNOR
2 hours ago, GOVERNOR said:
but, when i try to run the preboot. Its work, any idea how to fix?
use preboot
  • Thanks 1
8 hours ago, MaLd0n said:
use preboot
Thank sir! It is impossible to rename the Boot from Preboot to MacOs? I try to edit via clover entries but wont work.
no. use preboot
